HELP! Code: P1402
Old Jul 24, 2007 | 11:58 AM
minsbang's Avatar
HELP! Code: P1402
my '04 SL with 109k miles has been good to me....until today.
My check engine light came on, so I decided to stop by at Autozone to have it scanned. The scanner showed the code P1402. I followed the worker back inside and he prints out a long list of possible issues. (WTF?! I was hoping I'd get one or two issues but didn't expect it to be 8!) Here is what the printout states:
Troubleshooting P1402
Definition: DMTL Motor - Power stage fault
Probable Causes:
1- Open or short circuit condition
2- Poor electrical connection
3- Faulty DMTL - Module faulty
Definition: Heated catalyst power switch over temperature condition (Bank 1)
Definition: EGR System
Definition: Leak detection module pump circuit malfunction
Probable Causes:
1-Open or short circuit condition
2-Failed leak detection pump
Definition: EGR Function (Open)
Probable Causes:
1-Stuck open EGR valve
2- Failed EGR solenoid valve
3-EGR temperature sensor fault
EGR metering orifice restricted
Definition: Fuel level sensor circuit malfuntion
Probable Causes:
1-Open of short circuit condition
2-Poor electircal condition
3-Failed fuel level sensor
Definition: EGR Vacuum regulator solenoid valve short to positive
Explanation: Open or short curcuit condition
Probable Causes:
1-Failed EGR vacuum regulator solenoid valve
I don't have access to a scanner or a camera at this time so I had to type up exactly how the print out looks like. I am hoping someone can chime in and give me few tips. I have no clue where to start. Thanks in advance
Old Jul 24, 2007 | 12:46 PM
xoomer.com's Avatar
I Donate! Why Don't You?
P1402 _EGR Valve.
Had work performed on my max about 3 weeks ago for this same code.
Good case scenario - - > replace the EGR valve
Bad case scenario - - > replace the EGR valve and both cats.
Here is the TSB
http://www.nissanhelp.com/Ownership/.../NTB05-037.htm
Old Jul 24, 2007 | 12:51 PM
xoomer.com's Avatar
Somewhat related threads...
http://forums.maxima.org/showthread.php?t=512432
http://forums.maxima.org/showthread.php?t=450654
MyBlue92Maxima
Jan 23, 2007 03:33 PM
dss42
Aug 1, 2005 03:57 PM
dss42
May 3, 2004 12:39 PM
