Where can i get a Motor Mount for a 2004 Maxima? Help..
Old Aug 2, 2007 | 11:53 AM
falloutboy35's Avatar
hey guys.
i need some help, i took my car to a buddy of mine i used to work for pepboys
he told me one of my motor mounts is bad and i need to get a new one
i called the dealer and the idiot dude was like there are 2 motor mounts that are 237 dollars !! and this other one is 143 dollars
what the hell is up with that
i dont know exactly which one it is but it is a front motor mount...i dont kno where they are or what they look like
can i get this thing from anywhere online ????
please help
Old Aug 2, 2007 | 01:00 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=517573
http://forums.maxima.org/showthread.php?t=512479
First things first. Find out which one you need. Find one to replace it from one of the links above. Do a lot of research before you attempt, or take it in to get fixed.
For OEM, try http://www.trademotion.com/partlocat...49&catalogid=0
www.courtesyparts.com
They usually have better prices than local dealer.
Old Aug 2, 2007 | 03:21 PM
thank you so much. that first site does have the mount it is like 142 its a whole lot better than 237.
thanks again
i think it is my FRONT motor mount....if i need a new one, how soon should i replace it ??????
Old Aug 2, 2007 | 03:31 PM
CanadianMoFo's Avatar
The front mount has an electrically operated "stiffening" unit built into it. Which is why it's so darn expensive.
CM
Old Aug 2, 2007 | 07:36 PM
!PrjctMax!'s Avatar
CM
The front AND the rear do. I remember the tech disconnecting both of them when we were lowering my sub-frame.
Old Aug 2, 2007 | 08:12 PM
huh. thats crazy. yea they are expensive..
now lets say i buy the part online do you guys suggest i take it to the dealer to be installed or could this be done by yourself ???
is it easy or hard?
Old Aug 2, 2007 | 09:34 PM
!PrjctMax!'s Avatar
is it easy or hard?
Sub-frame needs to go so unless you have the tools and man power to do it yourself, I would suggest taking it to the stealership or having someone help you out at the least
Old Aug 2, 2007 | 09:42 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
what would a FAIR price be on this install?
Old Aug 3, 2007 | 04:21 AM
Ahhhhh right. I think it was the automatics that had the electronic mounts front and rear? And just the front electronic mount for the manual transmissions?
Old Aug 3, 2007 | 09:09 PM
!PrjctMax!'s Avatar
I had my FSB and MMI installed for $150, but I would say expect to get ***-rapped on prices at local shops since it requires lowering of the sub-frame and I'm sure the "book hours" on that are over the top!
IMO, you most definitely need a lift to do the MMI
Finkle
Sep 27, 2015 09:53 PM
schmellyfart
Sep 25, 2015 04:47 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
silver_i35
Aug 3, 2015 11:20 PM
