dtc1001
Old Sep 26, 2007 | 03:58 PM
marshallc's Avatar
dtc1001
my pos is throwing this code, says its a manufacture specific code
anyone know what it is?
Old Sep 26, 2007 | 04:00 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
P.M. NmexMAX .... or take his advice and goto autozone.. they will tell you what it is for cheap/free..
Old Sep 26, 2007 | 04:03 PM
marshallc's Avatar
i have the same code reader as autozone and it says manufacture specific code
Old Sep 26, 2007 | 04:23 PM
brio_max's Avatar
Learning English...
DTC U1000, U1001 CAN COMMUNICATION LINE PFP:23710
Description UBS0091Z
CAN (Controller Area Network) is a serial communication line for real time application. It is an on-vehicle multiplex
communication line with high data communication speed and excellent error detection ability. Many electronic
control units are equipped onto a vehicle, and each control unit shares information and links with other
control units during operation (not independent). In CAN communication, control units are connected with 2
communication lines (CAN H line, CAN L line) allowing a high rate of information transmission with less wiring.
Each control unit transmits/receives data but selectively reads required data only.
On Board Diagnosis Logic UBS00920
I'm not sure if this helps
Old Sep 26, 2007 | 04:25 PM
brio_max's Avatar
Learning English...
*1: This self-diagnosis has the one trip detection logic.
*2: The MIL will not light up for this diagnosis.
DTC Confirmation Procedure UBS00921
1. Turn ignition switch ON and wait at least 3 seconds.
2. Select “DATA MONITOR” mode with CONSULT-II.
3. If 1st trip DTC is detected, go to EC-147, "Diagnostic Procedure" .
DTC No.
Trouble diagnosis
name
DTC detecting condition Possible cause
U1000*1
1000*1
CAN communication
line
 ECM cannot communicate to other control
units.
 ECM cannot communicate for more than the
specified time.
 Harness or connectors
(CAN communication line is open or
U1001*2 shorted
Flood
