Clock running fast
I have reset mine twice in forty months - both times because the battery had been disconnected. Mine keeps marvelously accurate time.
edit - I do adjust for Daylight/Standard time, but only change the 'hour' at those times.
My fifth Gen Max had a clock that needed constant resetting - every few weeks I had to move it up a minute as it continued to run slow. But the '07 clock has been right on - I've not reset it at all other than for Daylight and Standard time adjustments.
Harry
Harry
Mine is fast too. Sometimes it helps b/c I'm always running late so it gives me a buffer of about 5 minutes. Once it gets to more than 5 minutes fast I reset it to the correct time and it gains about a minute every 2 or 3 weeks.
Yep, mine has always run fast as well, very strange. My car (a 2004) was built Sept. 2003. There has been past discussion about this on the Org before, and I thought that we had determined that all non-Nav Maxima clocks seem to run fast (those with Nav had clocks that kept perfect time), but maybe there is something else to it?
lightonthehill, you have a 2005 non-Nav Maxima, correct?
Monotaur - I have an '04 (manufactured the last week of May 2004) SL with Driver Preferred, Traction Control, Vehicle Dynamic Control (stability) and full-size matching alloy wheel/tire spare. I do NOT have the NAV (having vigorously collected road maps since 1948, I prefer to 'do it myself' when it comes to routing).
4MySwee & NismoMax80 - Some of my most prized maps were found at flea markets in the 1960s and 1970s. Such as my complete set of gasoline maps of each western state from the mid 1930s. In mint condition. They are very interesting. For instance, in 1935, the Clark County Game Ranch sat exactly where we now have the Frenchman's Flats Atomic Testing facility.
Another reason I didn't choose the NAV package is because my wife and I almost always take back roads and longer routes in order to see things off the beaten path. As often as not, once we are in the boonies, she drives and I navigate, with various kinds of maps piled all around me, and magnifying glass in hand. I try to avoid 'Yogi Berra-like' instructions, such as 'if you come to a fork in the road, take it.'
For those not deeply into maps, I have no doubt the NAV package would be the preferred method of navigating unfamiliar places.
To sort of return to subject, I would like it if we had a clock in the Maxima that obtained the time at regular intervals from satellite. All we would have to tell it would be the time zone we are in. My cell phone and several clocks at home are that way.
I guess I'm going to throw everyone for a loop and say that my 04's clock runs slow. It is 20 minutes slow, but I also just bought it, so it may have been wrong to begin with. Maybe I'll just let it go and see if it catches up to the right time. Then I will know for sure.
shilov
Feb 19, 2024 09:40 PM
t6378tp
Sep 29, 2018 04:27 PM
you can't imagine how i was laughing while reading your post.
