Altima Start button install
I found this thread on a 350Z forum:
http://my350z.com/forum/showthread.p...ot%3B+14+3%2F8 Here is a thread from when someone installed a Honda S2000 Start/stop button http://my350z.com/forum/showthread.php?t=220742 And a video of it working: http://video.google.com/videoplay?do...09615539395577 I am reading through it but I like the idea. Any thoughts? |
damn you do way to much, but I like it. If you can get it to work go for it
its nice but i think its very useless. no offence tho. :)
Just subscribing
I think it's pointless because you still have to put the key in the ignition. It's like you're adding an extra step just to start your car.
NO extra step. Instead of turning it to on, you push the START button. Its true its all about looks. It doesnt make starting the car any easier.
Well, you're putting the key in the ignition might as well turn it, right? The extra step is having to reach down and push the button. Just my opinion. If anything, I think it would look better somewhere near the ignition than down by the shifter if that's possible.
I think the point is for it to be seen. It looks pretty cool.
How about going a bit further and using the entire Alt system so you wouldn't even have to insert the fob?
Originally Posted by soundmike
(Post 5989361)
You could probably get a RFID receiver and somehow connect that to the harness, to start the car that way.
The sensor that picks up our stock chipped key, where is it located? Is the whole system right in the ignition column, or is it just a relay sensor that is controlled by the ECU? If it's in the ignition column, you could probably just replace it with the altima's ignition system. But if it's in any way connected to the ECU, I don't know how you could do it |
It's kinda like the BMW one- you still have to put the key in the ignition first, then press start button. Either way, I like it and think it's a cool feature.
Dear Deus,
I like this idea and had this installed on my IS300. It's not hard to do, the shop did it in about 3 hrs. I also had to insert the key. BUT, trust me - it is much, much cooler to look at. I would get more compliments on that and my halo's than anything else I did to the car. However, it would even be MORE cool if you could fabricate the entire Intellikey system from an Altima to the Maxima. Absolutely no one has done it yet, and I would really enjoy being able to get in and hit the start button without putting a key in at all. The door locks would be a whole other issue and probably a lot more work (you'd have to port over Altima door handles and the entire mechanical system in the doors). But you could probably do it with the start button. I'm guessing you'd knew a new key fob as well. Joshua |
Another thread on my350z.com. This product looks like its nearing production.
http://www.my350z.com/forum/showthread.php?t=296176 |
That is purely pointless and pissing money out the window. Wow, spend a couple hundred bucks to add another step to starting the car. Enough is enough with these types of mods... :soapbox:
Originally Posted by philoforlife
(Post 5989746)
Dear Deus,
Originally Posted by SickSE
(Post 5989913)
In most cars w/ intelligent keys, they use two steps button. Push one time for accessories power, second time for ignition. And at either point, if you step on the brake pedal, the engine will start. To stop, you push the button once to turn engine off, second time to turn accessries off. This can be done if the ECU can somehow detect the signal in the key, and a few relays; similar to auto start on alarm systems.
With this style of mod you technically arn't adding an additional step to starting the car, as the car can still be started with the key. For normal driving you can use the key, but when you want to impress all your friends you can push the button.
Originally Posted by KPierson
(Post 5989949)
anyway... dues ... Do it man.. just another first for us 6th gen maxima fans (2004-2006) Where do u plan on installing it?? location wise.. ? |
(Post 5989913)
Painting your calipers; Adding a "Nissan" sticker to aforementioned calipers; Adding headlight eyelids; Adding a spoiler (unless you plan to be driving over 140 MPH :rolleyes:) Adding a roof spoiler; Tinting your lights; Tinting your corner lights; Doing any LED additions; ETC on any visual mods. And, this does not cost a couple hundred dollars. I can promise you that. This is not pointless at all, I personally think this is one of the best visual mods out there (besides my personal favorite: the demon eye) and it does not mean you have to use the button at all (as Captain Obvious stated). Thanks for listening. Joshua |
Originally Posted by DeusExMaxima
(Post 5989870)
http://www.my350z.com/forum/showthread.php?t=296176 After reading this, I would recommend that you wait for this system rather than using an S2000 button like I had on my IS. While it is practical, this system utilizes an LED readout on the Altima button which tells you more about what's going on (and looks cooler than the S2000 button). For those of you who are lazy, here is what this is:
Originally Posted by my350z.com
http://img222.imageshack.us/img222/2923/13je7.jpg http://img222.imageshack.us/img222/3803/14db0.jpg What we have here is the developmental KPtechnologies 'Stage 2' Push Button Start system. This Stage 2 module still requires the use of the OEM key and transponder (Stage 3 is completely stand alone and is still in the engineering phase). The module is centered around a 'smart' control module that has a dedicated 20mhz central processor. The processor monitors various inputs and controls all the outputs that allow this module to seamlessly integrate with the vehicles ignition system. Through the push button, not only can the driver START the car, they can also STOP the car. Various LEDs on the button provide constant feedback as to the status of the system (LOCK, ACC, ON). The module also contains a sophisticated 'self program' feature that automatically programs the module for the specific installation at hand. Programmable features include internal or external "LOCK" LED triggering and the ability to turn tachometer monitoring on or off. The LOCK LED can flash with the OEM LED if desired, or can be flashed by the internal processor. The tachometer 'on' mode is nice because it prevents the starter from cranking if the motor is running (a nice safety feature). The development of this module is about 90% complete and it is ready to be installed in a test vehicle for further evaluation. All features listed above are currently working, with the exception of the tachometer monitoring (the hardware is working, but the control routines still need to be developed). We hope to send the first field units out to our testers in Early September. The target price for the Stage 2 module is ~$150 for all the parts to install it (module plus 2-3 relays). We are hoping to release the product to the public before the end of the calendar year. Besides this Push Button start module, KPtechnologies offers a wide range of custom electronic products. All of our products are engineered and manufactured in-house in the USA. Please check out www.KPtechnologies.com for more information about OEM window up modules, VDC/TCS memory modules, auto lock modules, Navi OK bypass modules, Electronic Beep modules, Mirror Tilt modules, etc. At this stage of the development we would love some feedback, thank you! I will be installing this. Joshua |
I wouldnt mind waiting for Stage 3. I would do the install as well. I just dont wanna wait til next summer or something. I get nervous when there is significant invasiveness, such as the Stage 3 system, even if you do get keyless starting. Stage 2 is minimally invasive and gets the job done and allows the driver the option of starting with key or using start button. Lets see how fast this project goes. I'd like to keep an eye on it and if KPierson can keep us posted here in maxima.org, that would be great!
Originally Posted by RHMax
(Post 5989946)
(Post 5990057)
You still have a mechanical wheel lock that will need to by bypassed/disabled before you get to the point of not needing to put the key in the ignition.
Joshua |
(Post 5990057)
(Post 5990093)
Steering lock isn't difficult to bypass. Anything else?
(Post 5989266)
(Post 5990103)
No, if you can simulate the electronic side the mechanical wheel lock would be the only thing that would prevent you from driving the car (unless you just wanted to go in circles).
I never said it was or wasn't difficult to remove the mechanical lock, I am simply stated that it needs to be done to be able to drive the car without inserting a key.
The difficulty of getting around the mechanical lock will depend on the car at hand, and how you want to bypass it (temporary/permanent). |
(Post 5990057)
http://video.google.com/videoplay?do...09615539395577 Kevin, I am glad you jumped in here and provided feedback. I appreciate all your work on this and hopefully this product can come to fruition in the 6th Gen Maxima and other cars. |
I was just thinking, what does the Altima have in place of the ignition switch? I imagine it doesnt have the wheel lock, right? Perhaps whatever is in the Altima could be retrofitted to our car, since there are a lot of parts that we share in common with with the Altima; or even teh entire ignition system? Any thoughts here?
(Post 5990322)
(Post 5989913)
The button pictured above is what the Altima has in place of an ignition switch. It is a Start/Stop button with 3 LEDs. If the car senses that the key is in the ignition, and the brake is pushed down you can push the button to start the car.
With the complexity of CAN based electronics it isn't very feasable to take a control unit from one car and put it in another, without replacing ever component on the CAN bus. On todays Nissans that would be just about any device with wires going to it. The 'mechanical' wheel lock is most likely controlled electronically (solenoid or actuator). This is just a guess, I have no first hand knowledge of how they lock the wheel. |
How is the 350Z locked. Its prolly similar
The 350Z is unlocked by the mechanical key.
(Post 5990374)
(Post 5990450)
Well, any 6th genners had their cars stolen?
(Post 5990443)
© 2024 MH Sub I, LLC dba Internet Brands
