MagnaFlow 14816's
Old Oct 8, 2007 | 06:17 PM
Mack's Avatar
MagnaFlow 14816's
Finally got some decent shots of these today.
PART #: 14816
DESCRIPTION: Double Wall, Straight Cut
2.25" Inlet, 3.5" Diam. Tips
6.5" Tip Length
5" x 8" Oval Body
14" Muffler Body Length
Old Oct 8, 2007 | 06:27 PM
NmexMAX's Avatar
dot dot dot ...
Soundclips > pictures, sometimes, and that time is now.
Old Oct 8, 2007 | 06:31 PM
BadBlackMaxSL's Avatar
Mack is Mackin'.
Looks great with the 350Z wheels. I like those but I liked the slanted cut tips a little more.
Old Oct 8, 2007 | 06:40 PM
Mack's Avatar
LOL man I was well on my way to getting some killer sound clips when it started raining! The luck! I'll get some soon guys. Doesn't sound as mean as the Chern beast but boy does it sound good.
Old Oct 8, 2007 | 06:49 PM
Uptown Maxima's Avatar
Looks great... I can't wait to get my Magnaflows so I can join the club. I prob won't start until the spring but with all the floks on here get their exhaust now, I don't know if I can hold out...
BTW Yes sound clips are a must.
Old Oct 8, 2007 | 07:13 PM
Majestic_MAx05's Avatar
Looking good bro!! Welcome to the magnaflow club!!
Old Oct 8, 2007 | 10:03 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
I LOVE MY MAGS!!!
and mack.. does it sound as good as mine :P lol jk ... i hope so since they are the same!
Old Oct 9, 2007 | 01:14 AM
jsmithsole's Avatar
*moderator*
Welcome aboard!
Old Oct 9, 2007 | 10:35 AM
xoomer.com's Avatar
I Donate! Why Don't You?
very nice indeed. Sticking out too much by my standards but looks great regardless. What else did you change in your exhaust system, I am sure it wasn't mufflers only. What dia. tubing did you run?
Old Oct 9, 2007 | 10:48 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
That's how pretty she looks!!!
Old Oct 9, 2007 | 11:14 AM
siggy580's Avatar
looks very nice!! did you compare the Mags with any other brands?
Old Oct 9, 2007 | 02:08 PM
KCMAXX's Avatar
KC's FINEST
Old Oct 9, 2007 | 02:17 PM
xoomer.com's Avatar
Originally Posted by KCmaxx
....... what?
Old Oct 9, 2007 | 02:27 PM
chernmax's Avatar
The only reason after market pipes look bigger sticking out is because most are bigger in diameter, have thicker and better polished sidewall and OEM pipes have shorter outer pipes to go more with the curvature of the rear bumper where as after market mufflers (duels) are equal length thus the outer ones stick out more. Hands down your pipes look 100% better then stock IMO. Great job!!!
Old Oct 9, 2007 | 02:37 PM
xoomer.com's Avatar
Thats why I was looking at setups with short'er tips.
1.)
14805
3.75" Tip Length
5" x 8" Oval Body
2.)
14807
2.25" Inlet, 4" Diam. Tips
3.75" Tip Length
5" x 8" Oval Body
vs.
14816
6.5" Tip Length
5" x 8" Oval Body
Now, I am by no means saying that his setup is not nice. Yes it is 100 times better than OEM. Its just that I am looking for a "tucked-in" style.
I've been quoted $300 for a job. It's a pro shop and the guy says he will do it right without cutting corners. Thats for replacing the crimp, doing the split and installing the mufflers. I just need all the 411 for the IDs of the pipes from you guys.
Old Oct 9, 2007 | 05:30 PM
KCMAXX's Avatar
KC's FINEST
....... what?
I wanted Mack to answer your question. I had to have 10 char. in order to post.
BTW the 14816' can be moved back. Mine don't protrude the rear bumper.
Old Oct 9, 2007 | 05:57 PM
chernmax's Avatar
1.)
14805
3.75" Tip Length
5" x 8" Oval Body
2.)
14807
3.75" Tip Length
5" x 8" Oval Body
vs.
14816
6.5" Tip Length
5" x 8" Oval Body
Dude, I'm a big advocate of doing what you think is best for you, I'm sure it will be different, but I'll dig it for that same reason...
Old Oct 9, 2007 | 05:59 PM
caldeputy's Avatar
PART #: 14816
6.5" Tip Length
5" x 8" Oval Body
Love the wheels, thinking of the same set up.
Old Oct 9, 2007 | 06:04 PM
Mack's Avatar
KCMaxx is right. These can easily be adjusted by the exhaust guy putting these on. I let mine go with his instinct as he does incredible work. Also, these really don't come out as much as it appears in some pics, like Chern said they are just SOOO much bigger than stock it may appear that way at times. Checkout from this angle and you may agree. And like Chern said, 100% better than stock for sure. Also, the guy widened my pipes from the Y-Split back. Not sure what dia he went with but it was larger than original.
Old Oct 9, 2007 | 06:07 PM
Mack's Avatar
By the way Xoom, I considered some of those as well. I bet the 14807's would look great. 4" TIPS!!! If you go with those DEFINITELY post some pics! I'd love to see 'em. Thanks Cal.
Old Oct 9, 2007 | 06:53 PM
KCMAXX's Avatar
KC's FINEST
Mack, what all did you have done? When I had mine installed (14816) I had them replace the stock resonator w/ a Magnaflow and also removed the "crimped" piece. The sound is amazing... Much deeper that just mufflers.
Old Oct 9, 2007 | 07:24 PM
Mack's Avatar
I haven't messed with the resonator but if I knew Magnaflow made one I would probably consider it. My next step is the Y-pipe then go from there. Sound is already incredible but I'm damn sure curious what your sounds like. Got any pics of that baby?
Old Oct 9, 2007 | 08:13 PM
philoforlife's Avatar
Isn't the "crimp" necessary for back pressure? Or am I thinking of something else?
Joshua
Old Oct 9, 2007 | 08:27 PM
shawndon's Avatar
KC,
I'm looking to cut off my greddy mufflers for a cleaner look and the 14816 caught my eye as well as the shorter 14805. But I only chose the 14805 because the 816's were out too far one of the reasons why I want to get rid of the greddy mufflers. How far in can you have them moved? I would want them almost flush with the rear bumper but out a little because I plan to do the stillen rear.
Old Oct 9, 2007 | 09:19 PM
xoomer.com's Avatar
any CELs or power loss at low range???
Old Oct 9, 2007 | 09:20 PM
xoomer.com's Avatar
Joshua
same question here. Chern, KC ?
Old Oct 9, 2007 | 11:03 PM
eK9aT10pSi's Avatar
what muffler would make the tips look like stock, like the "thin" metal look? i think jsmith had it on his max.
Old Oct 10, 2007 | 05:38 AM
Mack's Avatar
What would be the point?
Old Oct 10, 2007 | 06:35 AM
chernmax's Avatar
Yes, however if you are installing performance mods and have an A/F management computer and get it Dyno Tuned, you can help your car achieve the true potential of the performance parts as well as HP gains...
Old Oct 10, 2007 | 07:19 AM
xoomer.com's Avatar
chern,
If I don't have any computer now and don't want to dyno tune it yet what can I possibly change without throwing CELs and/or loosing power. Even if it was purely for cometic reason/noise. I was thinking of changing the crimped piece and everything from there on. Should I also change the resonator? Eventually y-pipe would be changed too.
Also, my understanding is that there are two options as far as the split goes in the back
either do 2.25" into 2x 2.25
or do 2.25" into 2x 1.75" which I think was the way catman had it split. I think somebody already asked this question in another thread but I didn't find it answered.
Old Oct 10, 2007 | 07:34 AM
JG1's Avatar
JG1
chern,
cattman uses a 2.5" main tube split into two 1.875" tubes
Old Oct 10, 2007 | 07:35 AM
xoomer.com's Avatar
thanks for correcting me on this.....anyone else wants to take a stab at answering the rest?
Old Oct 10, 2007 | 07:44 AM
siggy580's Avatar
do all the magna muf sound the same? (14816, 14807 etc?) also has any install the mags and removed the stock resonator if so is it too loud? Thanks
Old Oct 10, 2007 | 09:41 AM
mad-max's Avatar
I went with the 14807's since I wanted a more "tucked in" look with the tips flush to the bumper- just personal preference. Also I liked the 4 " tips because they blend in better visually with the muffler
Old Oct 10, 2007 | 10:12 AM
Sorry to go off topic, but where did you get that roof spoiler? Doesn't look small like the Ionic one...
Joshua
Old Oct 10, 2007 | 10:34 AM
eK9aT10pSi's Avatar
mack: to be total sleeper!
Old Oct 10, 2007 | 10:50 AM
Mack's Avatar
Now THAT is a great idea my friend. I digress. The "sleeper" is always a sweet strategy for sure.
And MadMax. Thanks for posting not only the rear shot with Magnaflows but the front vanity shot as well. You can really makeout how good the exhaust looks from that angle.
Old Oct 10, 2007 | 11:19 AM
xoomer.com's Avatar
Sweet jesus that looks good. Can you provide a picture looking straight at the rear from behind.
hmm rear from behind, that was weird. Anyhow, can you?
Old Oct 10, 2007 | 12:15 PM
KCMAXX's Avatar
KC's FINEST
I didn't notice any power loss with the "crimp" removed. If anything it felt stronger. I'll post some pics of what I had done (again...)
Old Oct 10, 2007 | 12:56 PM
KCMAXX's Avatar
KC's FINEST
A few pics....
Crimped section
