Car HID Xenon conversion Kit
Old Nov 21, 2007 | 08:52 AM
Lovemycar's Avatar
Guys i'm buying a kit online my first question is i want the 8000K bulbs will i have an issue with this burning my light housing and i have an 04 SE none HID
whats the bulb type please help
Old Nov 21, 2007 | 09:31 AM
BigPete's Avatar
Incognito
Im running 6k in my 04 SE. Havent had any problems. 9006 bulb type
Old Nov 21, 2007 | 09:37 AM
hdandb's Avatar
9006 And you will hate the 8k cant see SIHT! Go with 4300k or 5k not as blue but you can see a hell of alot more.
Old Nov 21, 2007 | 09:52 AM
!PrjctMax!'s Avatar
Show=Go with 8k head-lights, LED switch-back day-time lights (look exact to 8k lights)
"GO"=3k fogs FTW!
I think that would look hawt and the 3k will give you more visibility
Old Nov 21, 2007 | 09:55 AM
BigPete's Avatar
Incognito
ya i wouldnt recommend 8k they are really blue. Had them in my 98 milly.
6k is a nice white w/ purple/blueish tint
Old Nov 21, 2007 | 09:56 AM
scunner314's Avatar
When you install an HID kit do you loose the high-beams?
Old Nov 21, 2007 | 10:01 AM
!PrjctMax!'s Avatar
hmmmmm I'm pretty sure that you will either have halogen "high" beams, and HID normal beams, OR they might be all one bulb with a "flap" that opens them up for the high beams...
Someone chime in because I want to make sure as well
Old Nov 21, 2007 | 10:23 AM
roggeezy's Avatar
I dunno how the 6th headlights are but if ur highbeams are a seperate bulb then no you wouldnt, if its the same, you would need bixenons to have a high and low.
Old Nov 21, 2007 | 10:37 AM
xoomer.com's Avatar
I Donate! Why Don't You?
Factory HID comes with a single bulb. For high beams a curtain flips up exposing the upper portion of light emmited from the bulb. As far as I know, The curtain is part of the assembly/housing and not of the bulb. God, I am glad I got HIDs from factory.
Old Nov 21, 2007 | 10:56 AM
Kryogen's Avatar
What if you take a 04 max without xenon and you put a conversion kit in it?
There is no cut off and so you will blind everyone like hell???
Old Nov 21, 2007 | 11:14 AM
MiamiBlackMax's Avatar
well i have 8k and 3k fogs. i have no problem at night. as far as the high beam it will beam but its not good, tried it twice really quick b/c dont know what are the affect to the bulb or anything else to the headlight. if ur going for looks i would get 8k if ur going to see better go w/ 4-6k
Old Nov 21, 2007 | 11:27 AM
xoomer.com's Avatar
go with 5K for your headlights
Old Nov 21, 2007 | 11:32 AM
Lovemycar's Avatar
Ok so when i go to this site and trying to order, i'm stuck can some one help me
http://www.eliteev.com/ProductDesc.asp?pdid=1798 the bulb type it's giving me is D2S for 04 maxima i don't see 9006 on the sylvania web site can someone check this for me
i don't want to order the wrong thing or can some body send me the link where they bought there kits fot none HID 04 SE
Old Nov 21, 2007 | 11:58 AM
BigPete's Avatar
Incognito
I didnt have factory hids and the headlight housing is the same. Projector housing has a flap and it tilts to shine the light upwards.
Old Nov 21, 2007 | 12:19 PM
cyclopsmd's Avatar
D2S is the size you want. I had factory HID's, but I changed out to 6k bulbs. IMO, they look much nicer, and are still very bright...
Old Nov 21, 2007 | 03:23 PM
Lovemycar's Avatar
OK Thanks
Old Nov 21, 2007 | 03:47 PM
Majestic_MAx05's Avatar
I have 8k in mine. Have no problems and I can see at night too.
Old Nov 21, 2007 | 04:22 PM
Lovemycar's Avatar
Majestic_MAx05 did you have a none HID 04
Old Nov 21, 2007 | 04:29 PM
Kryogen's Avatar
Old Nov 21, 2007 | 04:35 PM
kzoosho's Avatar
Well it depends if you are a 6th gen with projectors then you do have a cutoff but you have halogen projectors. They wont be as good as oem but should be better than you halogen setup.
Old Nov 21, 2007 | 04:40 PM
Kryogen's Avatar
Whats the best place to buy a HID kit ???
Old Nov 21, 2007 | 04:47 PM
kzoosho's Avatar
Honestly a kit is a kit.The only ones that really last are oem. But a kit can be had on ebay for 79 bucks shipped. i have had mine for almost a year and a half and its still working so i mean its kinda hit and miss.
Old Nov 21, 2007 | 04:57 PM
Lovemycar's Avatar
http://www.eliteev.com/ProductDesc.asp?pdid=1798 will this fit my car i there's no return if this doesn't fit 04 se
Old Nov 21, 2007 | 05:00 PM
Lovemycar's Avatar
you guys keep telling me it's a 9006 bulb type here is the kit i found will this fit
Old Nov 21, 2007 | 05:06 PM
kzoosho's Avatar
well one way that you can find out what bulb you have is to pull one of your headlight bulbs and look at it.
Old Nov 21, 2007 | 05:08 PM
n3985's Avatar
大陆弟弟
For the 6th gen Maxima if you:
Have factory HIDs - you use a D2S bulb
No factory HIDs - you need a 9006 HID kit, buy it fom the group buy section, support a sponsor
No you will not blind anyone because the actual projector in the headlight is the same in factory HID and non-HID.
Old Nov 21, 2007 | 05:43 PM
northface202's Avatar
when everyone says kit and I go to this site and I see a box with looks like some power supplies and ****, so if i'm not mistaken I need a kit to add some HID's to my 07 max SE with factory head lights, which I think are some type of HID but not the bright blueish purpleish lights? I can't just by a bulb and call it a day?
Old Nov 22, 2007 | 10:06 AM
kzoosho's Avatar
It is but it aint . Same code but different bowls between the 2. Still wont blind anyone but not going to be as wide either.
Old Nov 22, 2007 | 10:08 AM
n3985's Avatar
大陆弟弟
LOL, yes you are right. But if talking to people who don't know what light bulbs they use, I think omitting projector bowl differences will simplify things more.
Old Nov 22, 2007 | 10:27 AM
kzoosho's Avatar
Sorry i am a lighting guy lol. I am retroing my forth gen now with rx330 afs projectors.
love that cutoff
Old Nov 22, 2007 | 10:46 AM
AscendantMax's Avatar
the cutoff on the halogen projectors isn't too bad. i made the swap to HID back in april. 9006 4300k kit bought from a sponser here.
it's not as sharp as other projectors though.
Old Nov 22, 2007 | 10:53 AM
kzoosho's Avatar
o so u like those ? they are nice but for you 6th gen guys you could use them., Now one thing you could look into if you are have lighting savvy would be to get a clear lens for your projector. That will clean up your cutoff and give you more color also.
Old Nov 22, 2007 | 11:02 AM
any clear lens will work?
Old Nov 22, 2007 | 11:33 AM
kzoosho's Avatar
No you need to find a 3 inch clear lens with the same or close to the focal lenth of yours. There are some out there that you can drop into your e55's . That what projector is in yout lights. Please visit www.hidplanet.com/forums and they can help you as well as i . Im a member there also. if you do a search there you will find some of my posts on the e55 and others as well.
Old Nov 23, 2007 | 10:13 AM
Lovemycar's Avatar
Thanks guys for your input i have ordered a HID kit now for the bumper how many screws are there or can i do this without taking the pumper off
Old Nov 28, 2007 | 05:13 PM
sonikbewm's Avatar
Ok guys, I have a question. Apparently I can't start a new thread yet since I am new here but I'm coming from a BMW with factory HID to this maxima without. If I was to get some OEM '07 maxima headlight assemblies with HID, will they plug right into the non-HID harness or is there something else that I would need to change? I really don't want to go the aftermarket HID kit route because I did that to a previous car and it just didn't compare to the OEM light pattern that was on the BMW. Thanks in advance for any answers.
Old Nov 28, 2007 | 06:37 PM
jsmithsole's Avatar
*moderator*
I just installed my 8K's and I love them, along with the switchbacks and yellow fogs it looks sweet! I think ia m going to go with 3000k upgrade for the fogs ASAP!
(pics soon...)
Old Nov 29, 2007 | 09:53 AM
TheSilverBullet's Avatar
Jamo's Silver Bullet
I'm new to the forum and I have a 05 Max with HID.
Please tell me that I will be able to just purchase some 8K HIDs and pop them right in? I'm looking to purchase some this weekend from xtralights.com. Or does anyone in the Washington DC area know a store where I can purchase some?
Please advise and thanks!
Old Nov 29, 2007 | 10:15 AM
Mack's Avatar
Anyone have pics of their 3k fogs? I was looking at my stock fogs the other day and they look hideous compared to the stock HID headlights.
Old Dec 1, 2007 | 01:19 PM
Lovemycar's Avatar
Ok guys i got my kit in the mail today and it came with two 8K bulbs two ballasts and the wires will i need and thing eles to get this going
