Transmission Leak
Old Dec 5, 2007 | 03:31 AM
Hilbe's Avatar
Transmission Leak
I posted this in another thread and decided I would rather have my own thread for diagnosis. I was under my car last night and noticed what appeared to be a transmission leak. I'm not a transmission guy and don't claim to be a mechanic so I was hoping someone would know for sure. Below is what I saw.
What do you guys think? Also, how do they (Nissan) handle these fixes? I have 57k miles on my car. I'm just wondering if they replace the transmission, fix it somehow, or what? Also how long does it take to replace a transmission?
Old Dec 5, 2007 | 04:59 AM
brio_max's Avatar
Learning English...
There's a TSB for an A/T leak, but i'm not sure if this is your case.
NTB05-055 5 SPEED FWD A/T LEFT SIDE OIL LEAK DIAGNOSTIC
"APPLIED VEHICLES: 2005 Altima (L31),
2004 - 2005 Quest (V42),
2004 - 2005 Maxima (A34)
APPLIED ENGINE : VQ35
APPLIED TRANSMISSION: 5AT
IF YOU CONFIRM
The transmission on the applied vehicle appears to have oil seepage or a leak on the left
side of the transmission (front of the vehicle).
NOTE: Be on the look out for:
• corrosion protection chemicals sprayed on the transmission
and/or
• lubricants which are sometimes used to ease the assembly process.
These may cause dust to accumulate (gather) on the left side of the transmission and
have the appearance of an oil leak......"
Old Dec 5, 2007 | 05:23 AM
anm6's Avatar
It looks like its leaking above the spot you took the picture and is running down whats above the picture?
Old Dec 5, 2007 | 05:25 AM
Hilbe's Avatar
The picture is from the front, right behind where the bumper plastic ends. I just stuck my head/camera under there from near the license plate mounting.
Old Dec 5, 2007 | 05:29 AM
anm6's Avatar
If you can't see whats above it I will look at mine today when I go home. Could be an oil leak seaping down, but cant be sure with out seeing it.
Old Dec 6, 2007 | 06:57 AM
anm6's Avatar
I took I quick look yesterday in the snow this sux man cold as hell. LOL
But the only thing up there that could leak down there is the valve cover,I wuold run it over to the dealer and let them look, they will probally just clean of the area and send you on your way to come back in a week unless it leaks there for them. Just let me know how it goes.
Old Dec 7, 2007 | 11:57 AM
Hilbe's Avatar
IF YOU CONFIRM
and/or
Do the TSB's have a recommended resolution? Just curious. I have to take it in here shortly and want to know my stuff. My stealership is TERRIBLE for service.
Old Dec 7, 2007 | 12:59 PM
brio_max's Avatar
Learning English...
Here you go 5 SPEED FWD AT LEFT SIDE OIL LEAK DIAGNOSTIC NTB05-055.pdf
Old Dec 7, 2007 | 01:46 PM
Hilbe's Avatar
Thanks. I pulled this PDF up on my ipod and showed the tech. Ended up being a leaky gasket. $245 to fix. Waiting now in the waiting room.
Old Dec 7, 2007 | 02:16 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
so it was not covered?
Old Dec 7, 2007 | 02:30 PM
jtkonfire's Avatar
i have a similar problem. my 1995 maxima has a tranny leak because the seal between the bell and the tranny. i just need replace the seal and keep my eye on the tranny oil. it could also be a drive axle that isn't seated right.
Old Dec 7, 2007 | 03:09 PM
Hilbe's Avatar
No it was not. They are actually keeping my baby overnight to let the sealant cure.
Know what was funny is the tech noticed a metal on metal noise. I ended up having the cracked metal bracket that attaches to the end of one of the headers. They're going to to take that thing off for me in the morning.
Old Dec 14, 2007 | 10:34 AM
anm6's Avatar
Why was this not covered under the factory drive train warrenty are you over 60k.
Old Dec 14, 2007 | 11:38 AM
Hilbe's Avatar
Powertrain apparently only covers things "internal to the transmission" according to the stealership. Since it was a gasket, not covered. In the gray area if you ask me...
Old Dec 14, 2007 | 11:52 AM
anm6's Avatar
I was in the business for years gasket on the tranny or engine are drice train, hell I have replaed spark plugs under drive train. I would fight the bill with Nissan there is no way you should have paid.
James92SE
142
Jan 2, 2024 09:23 AM
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
Socalstillen
Sep 20, 2015 11:46 PM
