Changing a brake light 2004 Maxima?
I looked in the sticky under specs and info to see if someone could tell me how to change a brake light bulb. Some threads led no where and I couldn't find any info?
Any help would be appreciated....I assume you change it from the inside of the truck but the liner has to be removed?
It's a very user hostile design. See my post from a few months ago (9-15-2007).
http://forums.maxima.org/showthread.php?t=536302
be very carefull when removing the brake light. The surrounding painted parts are plastic and will brake or crack if you are not cautious. Id suggest using a pannel pop, but that may not work for everyone if you are not sure how much pressure you use. upgrade your reverse bulbs while you are at it (BRIGHTER) try V-leds on ebay to get them.
FTR follow the instructions at the top of the stickies, and then they will work.
with the entire forum revamp, to see old links: change "showthread" to "oldthread" in your address bar after clicking the link.
I have a "how to" in there with pics...
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
