failed inspection? Need help .....
Old Dec 15, 2007 | 11:42 AM
figueroa1357's Avatar
Slo- E
MY car failed inspection ...computer from autozone read... car too lean bank 2...does anyone know how to fix this....btw yes my sevice engine soon light is on...Thanks in advance ...2004 maxima.... 60 k miles....
Old Dec 15, 2007 | 11:45 AM
redls1's Avatar
MAXIN' ON
o2 sensor!
Old Dec 15, 2007 | 12:19 PM
Slo- E
Originally Posted by redls1
o2 sensor!
which 1 there 4 sensor...
Old Dec 15, 2007 | 12:52 PM
Oolatec's Avatar
One of the 4.
Old Dec 15, 2007 | 01:08 PM
tyman's Avatar
Originally Posted by Oolatec
One of the 4.
Old Dec 15, 2007 | 01:53 PM
Hilbe's Avatar
Give us the numeric code.
Old Dec 15, 2007 | 02:09 PM
Slo- E
PO174 IS THE CODE
Old Dec 15, 2007 | 03:35 PM
redls1's Avatar
MAXIN' ON
I did a basic google search and came with this,
PO174 - Fuel system for bank 2 is too lean, rich or lean air/fuel ratio condition engine bank two
1- Suspect fuel pressure or Mass Air Flow sensor
2- Failed HO2S21
3- Ignition misfire condition
4- Fuel injector problem
5- Engine mechanical condition
It said to check for vacuum leaks, your maf sensor, injectors or coils. Sorry I couldnt be more help.Besides the light being on is there any driveablilty problems?
Old Dec 15, 2007 | 03:48 PM
cefiro80's Avatar
It would help to know if there any drivebility problems.
Old Dec 15, 2007 | 03:53 PM
RHMax's Avatar
Newbie just Registered
Are you stock?
Old Dec 15, 2007 | 04:01 PM
AllBlackMax's Avatar
aka The Doom Ship
very simple fix! Go to another autozone, have the code cleared and immediately go for inspection(some place else). Clearing the code should buy you enough time to pass.
Either that or go to a hood inspection place and pay a little extra.
Old Dec 15, 2007 | 05:50 PM
Slo- E
tried that already....they cleared the codes they still came up on the inspection
Old Dec 15, 2007 | 05:52 PM
Slo- E
just running sluggish....evreything else is fine...thanks in advance.
Old Dec 16, 2007 | 08:57 AM
madmik's Avatar
Correct behavior. Once you clear the code, the ECU goes through a cycle to re-evaluate the proper functionning of all the emission components. It takes 5-10 miles and specific road conditions. Until the cycle is complete, you may not pass. You need a Consult-II or a full function ODBII analyser to see when the cycle is done.
Old Dec 16, 2007 | 08:59 AM
KCMAXX's Avatar
KC's FINEST
Just what are these "specific road conditions?"
Old Dec 16, 2007 | 10:37 AM
xoomer.com's Avatar
I Donate! Why Don't You?
yeah, pretty much
Old Dec 18, 2007 | 08:35 PM
madmik's Avatar
Exerpt from service manual under Engine Control system:
SYSTEM READINESS TEST (SRT) CODE
System Readiness Test (SRT) code is specified in Service $01 of SAE J1979.
As part of an enhanced emissions test for Inspection & Maintenance (I/M), certain states require the status of SRT be used to indicate whether the ECM has completed self-diagnosis of major emission systems and components.
Completion must be verified in order for the emissions inspection to proceed.
If a vehicle is rejected for a State emissions inspection due to one or more SRT items indicating “INCMP”, use the information in this Service Manual to set the SRT to “CMPLT”. In most cases the ECM will automatically complete its self-diagnosis cycle during normal usage, and the SRT
status will indicate “CMPLT” for each application system. Once set as “CMPLT”, the SRT status remains “CMPLT” until the self-diagnosis memory is erased. Occasionally, certain portions of the self-diagnostic test may not be completed as a result of the customer's normal driving pattern; the SRT will indicate “INCMP” for these items.
NOTE:
The SRT will also indicate “INCMP” if the self-diagnosis memory is erased for any reason or if the ECM memory power supply is interrupted for several hours. If, during the state emissions inspection, the SRT indicates “CMPLT” for all test items, the inspector will continue with the emissions test. However, if the SRT indicates “INCMP” for one or more of the SRT items the
vehicle is returned to the customer untested.
Pattern 1:
 The engine is started at the engine coolant temperature of −10 to 35°C (14 to 95°F) (where the voltage between the ECM terminal 73 and ground is 3.0 - 4.3V).  The engine must be operated at idle speed until the engine coolant temperature is greater than 70°C (158°F) (where the voltage between the ECM terminal 73 and ground is lower than 1.4V).  The engine is started at the fuel tank temperature of warmer than 0°C (32°F) (where the voltage between the ECM terminal 107 and ground is less than 4.1V).
Pattern 2:
 When steady-state driving is performed again even after it is interrupted, each diagnosis can be conducted. In this case, the time required for diagnosis may be extended.
Pattern 3:
 The driving pattern outlined in *2 must be repeated at least 3 times.
Pattern 4:
 Tests are performed after the engine has been operated for at least 17 minutes.  The accelerator pedal must be held very steady during steady-state driving.  If the accelerator pedal is moved, the test must be conducted all over again.
*1: Depress the accelerator pedal until vehicle speed is 90 km/h (56 MPH), then release the accelerator pedal and keep it released for more than 10 seconds. Depress the accelerator pedal until vehicle speed is 90 km/h
(56 MPH) again.
*2: Operate the vehicle in the following driving pattern.
1. Decelerate vehicle to 0 km/h (0 MPH) and let engine idle.
2. Repeat driving pattern shown at right at least 10 times.
– During acceleration, hold the accelerator pedal as steady as possible
etc, etc, etc. Just like the ECU will re-learn pedal position, throttle body position, etc after it is unplugged, it has to re-evaluate the emission components.
Old Dec 27, 2007 | 02:54 PM
Slo- E
thanks evrey one... got it fixed ... IT was the Air_fuel_control sensor... got my inspection.... hope this helps someone else
Old Dec 28, 2007 | 08:10 AM
JBush's Avatar
can you give us a price on the fix?
Old Dec 29, 2007 | 11:27 AM
Slo- E
120.00 for installation...180 for the part from dealer...hope this helps
Old Dec 29, 2007 | 12:37 PM
SuperMario's Avatar
My Service Engine Soon light just came up yesterday morning when I arrived to work. However, my car doesn't feel sluggish at all, feels just normal. My engine is stock, no mods at all.
The only thing that could be explained is I put one of those fuel treatments on my last gas fill up. I haven't done one of those in this car since I bought it used in March. Could this be the reason why the light turned on? Does this mean I have to spend $300 to fix this issue?
Old Dec 30, 2007 | 11:29 AM
Slo- E
try that fuel treatmen first...ps floor it make sure it does not smoke...make sure your exhaust dont smell like rotten eggs...late
Old Dec 31, 2007 | 11:19 AM
madmik's Avatar
Loose gas cap? Otherwise probably just coincidence but something is wrong. Get the code read at Autozone.
Old Dec 31, 2007 | 11:40 AM
Cutler's Avatar
Aren't 02s part of the emissions system warranty? If so, it should be covered until 80k.....
If not replace it yourself...
Old Dec 31, 2007 | 07:30 PM
SuperMario's Avatar
Can anybody who really knows verify this, perhaps a technician or a Nissan employee?
Does the warranty go above 60K for '04 and above?
Old Dec 31, 2007 | 11:47 PM
SDMaxima's Avatar
the fuel treatment will give you a light sometimes. Just burn up the gas and it will clear
Old Jan 2, 2008 | 08:46 PM
SuperMario's Avatar
Great, I have to fill up tomorrow, almost done with my 'fuel treatment' tank.
Thanks for the knowledge!
Old Jan 3, 2008 | 07:03 PM
Slo- E
80 k on the catalic converter..only...my dealer mechanic told me so...i was hoping that was it so i would not pay anything
Old Jan 3, 2008 | 08:06 PM
SuperMario's Avatar
So, I had to stop in the Turnpike to put gas in chilly South Florida. With only $9 the light finally turned off.
I'm just glad I don't have to see it anymore. And yes, it was freezing this morning!!!
09maxshawn11
Sep 30, 2015 10:28 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
ColdCananda
Sep 20, 2015 10:45 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
