2005 maxima struts
Old Jul 17, 2008 | 06:08 PM
wadecarlson's Avatar
2005 maxima struts
2005 maxima struts
well its that time to replace my struts. i wanted to get a few opinions bfore i bought. i dont really want to throw any brand names out there so i can get new opnions. what do you guys think? any good ideas?
Old Jul 17, 2008 | 06:09 PM
Shoey1's Avatar
i hear KYB struts and Progress springs are just about the best hookup out there, alot fo guys on here are running them with no major issues
Old Jul 17, 2008 | 10:14 PM
MiamiBlackMax's Avatar
i think the KYB are the only ones out there rite now since they stop making the adj ones
Old Jul 18, 2008 | 04:51 AM
DEENYCE718's Avatar
Just out of curiousity, are KYB and OEM struts equal in quality?
Old Jul 18, 2008 | 05:12 AM
95Max's Avatar
Just so you know the KYB GR-2 is rather stiff. So depending on where you live....it can be enjoyable or not. I have the Gr-2 with stock springs and I am in the NJ/NY area...well lets just say that with the crappy roads here I would not buy them again.
Old Jul 18, 2008 | 05:57 AM
VigilanteMax's Avatar
There is tons of info about struts on here, but the GR2s are nice. As far as OEM, the are better than factory equipped, especially if lowering. Dont forget to replace your strut mounts if you are doing this as you will probably have to down the road anyways.
Old Jul 18, 2008 | 06:36 AM
KC2010's Avatar
Get the KYB mounts that come with the strut bearings.
Old Jul 18, 2008 | 07:48 AM
thx! looks like im going with the gr-2 - i liek a stiff ride.
Old Jul 18, 2008 | 03:58 PM
xorbitman's Avatar
KYB with Eibach here and no problems: Replaced rubber inserts.
Old Jul 18, 2008 | 06:56 PM
rick sambora's Avatar
what inserts? Are you talking about the 54034-ZK00A spring rubber seats?
Old Jul 24, 2008 | 02:14 PM
chris350's Avatar
is strut problems a common issues with the 6th gen max? I have a 06 Max that I got around thangsgiving of last year, my front struts needs replacing...I had a 97 max before, I rode the stocks since I got it in 97 and replaced them in 2005 with kyb's. So the life time of those struts compared to the 06' is way shorter.
So I want to keep it stock, I was looking on courtestparts and noticed that the part number mentions that the struts are year 2. I dont know if thats an issue they resolved but my mechanic said that 97 % of the 6th gen max's that roll in have strut issues.
Besides the strut, the strut mount and the strut bearing, anything else that I should get?
Old Jul 25, 2008 | 06:21 AM
KC2010's Avatar
I would get Racingline endlinks and upgrade the sway bars. That's my next step.
Then I'll go with aftermarket tie rods and control arms.
You're right! My 2001 maxima had some tough struts. I lived down a dirt road, played in a band and carried my stack and other goodies all over town. Never did I hear a peep out of the struts. What WAS funny is when my wheel bearings on the right side went out I noticed then I had two bad struts as well. But that was 5 years later.
My 2005 has 33,000 miles on it. And some how I have bad struts??? The strut bearings are shot? Who's the contractor making the struts for Nissan now?
KYB's and Eibach go on this weekend. I guess I'll have to gut out the whole front end and rebuild it myself since Nissan sucks at it so bad.
Old Aug 6, 2008 | 05:13 AM
Talon05's Avatar
Rattling front end
[B]Hey Guys my 2005 Maxima SE has rattling when I drive over small speed bumps and pot holes. But quiet on a smooth surface. Is this a strut and bearing issue. Thanks Anderson Also do I have to replace with dealer parts.
Old Aug 7, 2008 | 10:27 AM
KC2010's Avatar
You might have something else loose under the hood that rattles. Most struts that go bad make a "BONK" type sound. I've never heard a strut rattle. Of course, my knowledge is limited to only experience with my car.
You don't need to use dealer parts. You can always buy after market. I use Mike from import replacement parts. Search the org and you will find plenty of group deals from him and many other auto parts companies.
Kevin
Originally Posted by A. Clayton
[b]Hey Guys my 2005 Maxima SE has rattling when I drive over small speed bumps and pot holes. But quiet on a smooth surface. Is this a strut and bearing issue. Thanks Anderson Also do I have to replace with dealer parts.
Old Aug 7, 2008 | 11:50 AM
That would be your front endlinks. I accept paypal for the diagnosis...
Old Aug 7, 2008 | 12:26 PM
thealliance43's Avatar
would these be good for replacements... i have that bonk! noise
http://cgi.ebay.com/ebaymotors/KYB-S...mZ370073560706
Old Aug 7, 2008 | 12:35 PM
Those are just mounts and no part #. The only noise that your strut mounts can make are when you turn the car stationary. I believe the part # you are looking for for the mounts is SM5409
Old Aug 7, 2008 | 03:34 PM
Talon05's Avatar
Thanks VigilanteMax
Hey thanks for the feedback, I do alot of driving and when I heard that sound, it had me concerned. Glad to be part of this board with other Maxima owners.
Old Aug 9, 2008 | 10:12 AM
figueroa1357's Avatar
Slo- E
gabriel struts....rate them vs oem
has anyone installed theses before.....my struts are bad...trying to decide whether oem or gabriels???
Old Aug 12, 2008 | 03:59 PM
BIG GILLES's Avatar
KYB.
Old Oct 20, 2008 | 02:39 PM
pavetim's Avatar
What would be some options on the strut mounts someone on here said the KYB strut mounts has too much play in them. I don't want to go back to OEM so what are some other options?
Old Oct 20, 2008 | 08:12 PM
maximaaa04's Avatar
need opinion on the strut mounts alsooooo....iv got the kyb struts with the eibach kit but my left strut mount have done bad 2nd time in the last 5 months....im not going to get the kyb strut mounts any other options out there........
Old Oct 21, 2008 | 06:21 AM
KC2010's Avatar
Too much play? They're spec'd to OE numbers. Mine are just fine. I even replaced my stut mount plates when I did my struts. There's nothing wrond with the KYB line of products from my searching in the threads. If you're afraid then go with OE replacements.
Old Oct 21, 2008 | 06:24 AM
bambino's Avatar
hmm, when I had to replace mine, I was at my dealership doing a regular maintenance check, and they replace them for free, it was under warranty.
Old Oct 21, 2008 | 09:33 AM
pavetim's Avatar
I'll probably go with KYB or the MOOG I mean if my OEM went out after like 40K do I really want to use those again lol. I can get KYB or Moog from advance auto so i'll probably go with one of those.
Old Mar 16, 2010 | 05:14 PM
Praetorian29's Avatar
I know this is a bit of an old reply, but I'm just now replacing my struts and shocks (and doing the strut mounts, too, while I'm at it).
I thought my vendor (car-stuff.com, which I do *not* recommend) shipped me the wrong item because it says Altima Strut Mount on the box, so I did what just about any self-respecting Maxima owner would do with a question about parts... I came back to these forums after a long absence.
Lo and behold, this and four other threads answered my questions about this part number and its quality/performance.
Thanks, Maxima.org! *thumbsup*
Old Mar 16, 2010 | 09:49 PM
RAZ76's Avatar
Rockautocom is what I use for all my cars. Never had any issues with them.
Old Mar 16, 2010 | 10:26 PM
if you want a stock comfortable ride go monroe struts
Old Mar 16, 2010 | 11:34 PM
RAZ76's Avatar
I have Eibach and KYB GR-2, rides great.
Old Feb 21, 2011 | 02:24 PM
dpuntier's Avatar
I have the same car. And the same thing happend to mine. I went to 3 different mechanics and they found nothing. At the end I found out that the cat was bad and that's where the rattling noise was coming from.
Old Mar 30, 2011 | 09:54 AM
DMAXI06's Avatar
What is the opinion on Monroe sensa trac shocks and struts?
Old Mar 30, 2011 | 03:43 PM
KillerZero259's Avatar
i got a full coilover kit, BC racing, when my structs were blown, but hell the ride is STIFF lol
Old Mar 30, 2011 | 04:21 PM
BadBlackMaxSL's Avatar
I have the Monroe struts and love them. Worth the extra cost plus the life time warranty.
Old Mar 30, 2011 | 09:10 PM
DMAXI06's Avatar
good to hear. im stoked to get them this summer
Old Mar 31, 2011 | 09:12 PM
chris350's Avatar
same here, I live in queens, NY.. KYB are stiff.. i don't like them too much. The stock ride is ok but having blown 2 sets of stock.. I'm hoping the KYB will fair better..
Old May 7, 2011 | 01:58 PM
mateo420247's Avatar
Oem mounta are actually a little bulkier than any aftermarket...they seem to work the best...wouldn't mess with aftermarket mounts as Maxima's are very heavy cars and the factory mounts are better...
MAXSE5SPD
Aug 23, 2015 12:06 PM
wingnut2006
Aug 15, 2015 04:16 PM
cmpowell86
Aug 10, 2015 12:35 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
