WATER PUDDLE!!1
WATER PUDDLE!!1
hey guys just wanted to inform you that im starting to get a huge leak of water going to the back seat. does anybody or has anybody had that issue?? anything i can do without having to get my arm taken off at a mechanic shop?
haha i dont got the skyview i got the sunroof but i believe its the ac dripping water...not to long ago i switched it on and i heard a swish of water...i was like wtf!!! so im thinking of takeing it to a mechanic unless someone can point me in the direction of what i should do go to mechanic or attempt to look for it myself. i just thought when the a/c leaked inside it was in the front not to the back. ya know
Where is the puddle, on the back seat or on the floor? If it's on the seat then it's probably coming from the rear window (or somewhere above) And is it a puddle or a leak? Is it there when you get in the car or after you're driving??? More details might help us help you...
The drain tube for the A/C that comes out under the car (where you see the little puddle of water when you stop and have been running the A/C) had clogged up because we were visiting some of her relatives and they lived out dirt roads. It backs up inside of the car in the floors if it gets clogged up and all they do is run something up that tube and all of the water comes pouring out but now you have to have your carpets cleaned and dried out.
when the a/c is running im assuming it was throwing the water out to the back floor panel. i cleaned it once and then it happened again. i dont know if its because the tube that runs to the rear a/c is loose and when i get passengers in the back when they step on it they knock it off from where its connected. the insallation of the carpet is what seems to be holding alot of water in it.
tried it and no leak. oddly the water is no longer there....i think i might have unclogged it when i last tried to clean the tube. so problem might be solved as of now, if it happens again ill take it to the shop.
check on the floor of the front passenger seat.. all the way to the front of the floor towards the left.. yull see a hose/tube there.. make sure its going into something and not just hanging there loose.. lol
RWCreative
Sep 21, 2015 11:01 AM
