Code P0455
Old Sep 23, 2008 | 09:33 AM
!PrjctMax!'s Avatar
Code P0455
I was driving around 40mph and suddenly hit the brakes, and right when I hit the brakes my SES light came on.
I got it checked yesterday and it is P0455 EVAP Control System Leak (Large)
Both the AutoZone guy and my mechanic said that it's nothing to worry about performance wise or how the car will act. It will just leak out gas vapors which will result in a failed emissions.
My gas cap is tight and I will be un-plugging the battery soon, but any other remedies to look for besides replacing the canister?
thanks,
dan
Old Sep 23, 2008 | 09:38 AM
TAZ's Avatar
TAZ
are you over the mileage for your emissions warranty? 7yrs/80000 or something like that? if not who cares just go to the dealer and make them fix it.
chernmax's Avatar
Nations 1st 6th Gen Turbo
Clear the code, if it's a real problem it will come back...
Old Sep 23, 2008 | 10:26 AM
Lovemycar's Avatar
might be one of your cats if it is your covered up till 80K
Old Sep 23, 2008 | 11:47 AM
VigilanteMax's Avatar
cats, heat shield most likely.
Old Sep 23, 2008 | 02:57 PM
!PrjctMax!'s Avatar
No warranty of any sort...
My tech was saying that it's the EVAP solenoid or canister?
What's with these cats I'm hearing about...?
I disconnected the battery and the light went away, but when I womped on it a little bit, the light came on.
Old Sep 23, 2008 | 03:01 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
Where is Nmex when you need him .. LOL..
Hope the cat has not broke apart and gone into the engine ... talk to kamski about that ejj?
Old Sep 23, 2008 | 03:12 PM
Shoey1's Avatar
FYI. cats have nothing to do with evap emissions guys. your tech is right but for other people with an evap leak "SMALL", it can sometimes be a a loose gas cap or a bad rubber seal in the gas cap. it can also be from corrosion on the filler neck and teh cap wont seal tight. these are just more common examples i have noticed from customers coming into the shop i work at. this is not the be all to end all evap answer.
Old Sep 23, 2008 | 03:20 PM
brio_max's Avatar
Learning English...
From the FSM section EC page 346
Possible cause:
 Fuel filler cap remains open or fails to
close.
 Incorrect fuel tank vacuum relief valve
 Incorrect fuel filler cap used
 Foreign matter caught in fuel filler cap.
 Leak is in line between intake manifold
and EVAP canister purge volume control
solenoid valve.
 Foreign matter caught in EVAP canister
vent control valve.
 EVAP canister or fuel tank leaks
 EVAP purge line (pipe and rubber tube)
leaks
 EVAP purge line rubber tube bent.
 Blocked or bent rubber tube to EVAP
control system pressure sensor
 Loose or disconnected rubber tube
 EVAP canister vent control valve and the
circuit
solenoid valve and the circuit
 Fuel tank temperature sensor
 O-ring of EVAP canister vent control
valve is missing or damaged.
 EVAP control system pressure sensor
 Refueling EVAP vapor cut valve
 ORVR system leaks
Old Sep 23, 2008 | 04:40 PM
!PrjctMax!'s Avatar
Does the EGR valve have anything to do with it? I ask because I had to disconnect it from the UIM when I was doing my SSIM and then putting my OEM UIM back on.
Old Sep 23, 2008 | 06:55 PM
Nietzsche's Avatar
EGR shouldn't matter, hook up a smoke machine to the EVAP port and try and find the leak. A good scan tool should be able to turn the solenoid on and off for testing purposes. Without going throught that it's a guess as to which part is bad.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
