Walbro fuel pump in a 6th Gen
Old Oct 3, 2008 | 04:57 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
OK, I had been pumping more air (well I'm boosted) and wanted a better fuel balance so I talked with Tim at Speed Force Racing who makes the 6th Gen Turbo kit and he recommended installing the Walbro 255 fuel pump which I did yesterday. After install I noticed a high pitch noise which is not so noticeable inside since I sound proofed the back seat area and my trunk was already done previously. Anyway I spoke with Tim at SFR and Googled this Walbro noise problem and low and behold, it's normal, so with that said, anyone upgrading their Fuel pump to a Walbro 255 should expect the same thing!!!
Walbro 255 Fuel Pump
Back seat removed prior to removal of fuel pump assemply
6th Gen Fuel pump assembly removed/new fuel pump installed
Under rear seat area sound proofing using B-Quiet Ultimate.
Old Oct 3, 2008 | 02:02 PM
chernmax's Avatar
Bababababababababababa Bump!!!
Old Oct 3, 2008 | 02:41 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
so are you supposed to feel a difference or is this a Mind pleasing mod
Old Oct 3, 2008 | 06:41 PM
chernmax's Avatar
This is a better air/fuel mixture mod!!!
Old Oct 3, 2008 | 11:25 PM
eK9aT10pSi's Avatar
this is an excellent fuel pump. had one in my boosted ek9. yeah, that sound at first scared me but thats how hard its "sucking" fuel from the tank through line.
ever since then, i turn my key to position 2 for a few seconds then crank the car. i got in the habit of timing it from the civic.
Old Oct 4, 2008 | 08:31 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
so i assume it would be good for me to get one with my mods listed below correct?
Looks like install is very simple?
Price? place?
Old Oct 4, 2008 | 08:34 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
http://www.racingworks.com/walbro255.htm
Found one there for 255 but its for the 94-03 maxima's...
part number is wal 341858.. is that the same you have?
Old Oct 5, 2008 | 08:49 AM
chernmax's Avatar
IMO unless you upgrade your fuel injectors to 440cc and install headers, you may not see any benefit by doing this, but that's not to say you cannot do it and have this mod completed before you move forward with other mods as they become available. Contact Tim at Speed Force Racing in California, he sells the Walbro 255 for about $99.00 and knows exactly which one you will need for the Maxima, your probably close enough to him to even pick it up, he shipped mine DHL ground to the east coast for $7.00 and I got it in 4 days:
TurboTim
Tim@speedforceracing.com
619-249-5101
Old Oct 5, 2008 | 10:45 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
Sounds good man ! Thanks for the info!!!!
Old Oct 6, 2008 | 03:55 AM
chernmax's Avatar
OK, not going to start a new thread since this is a small project mod, but I custom made an oil catch can.
Old Oct 6, 2008 | 04:05 AM
ramberg's Avatar
GrandPa
Very nice. ^^ Can you please tell what this does.
Old Oct 6, 2008 | 04:31 AM
chernmax's Avatar
Residual oil off the heads is normally ported back into the CAI and burned off through the intake manifold (you can see the hose going into your CAI), when you go boost, more oil tends to be ported off the heads thus was saturating the filter and lightly spraying into the engine bay area which will make things dirty and greasy. So an oil catch can placed in line will catch the oil and allow you to remove the residual all while keeping the filter side clean and breathable.
Old Oct 6, 2008 | 04:45 AM
Digital's Avatar
VIP
Nice work Chern!
Old Oct 6, 2008 | 09:27 PM
NiZMo1o1's Avatar
Chern , you need to route the catch can behind the intake manifold, the oil flows back into the manifold on mines, I had mines setup where yours is and I didnt catch ANY oil or blow back into the intake pipe.
I found out in the back of the manifold is where the oil is blowing out and back into the manifold, when I pulled my manifold off it was cover in oil all over inside and the VIAS.
Just a thought , maybe since your boosted the oil may blow by there.
Old Oct 6, 2008 | 09:31 PM
JonBlz's Avatar
a.k.a. STuNtMAN
with that walbro fuel pump dont let your gas go close to E because it will bog all day until you put gas walbro tends to suck up alot of gas i have it in my 99 and im boosted and let me tell u i be scared to let my caar get low on gas lol
Old Oct 7, 2008 | 04:06 AM
chernmax's Avatar
My oil was coming out from the small filter and I put the oil catch where Speed Force Racing (Turbo Tim) indicated it should be. I will leave it where it's at for now and see what happens first. Thanks for the input, I'll keep my eye on it and report back if a reconfiguration is in order. Thanks again
Old Oct 7, 2008 | 04:08 AM
chernmax's Avatar
Thanks and agree, I have never let my gas bottom out on any vehicle I have owned, and I have owned at least 14 vehicles...
Old Oct 7, 2008 | 05:16 PM
zlyricist's Avatar
a lot of people are against those breather filters, and im starting to feel the same....it limits the crankcase ventilation and is said to blow out gaskets/pistons rings. i was running 300whp daily in my 91mx6, and granted it had over 200K miles, i didnt have any problems until i put one of those in. the headgasket went within that same month...
Old Oct 7, 2008 | 05:28 PM
chernmax's Avatar
That's why I put the in line oil catch can, the breather gaskets tend to breath better when they are not saturated in oil!!!
Old May 9, 2009 | 06:07 PM
My-Body-Is-Ready's Avatar
i just got this installed last week and that whining is quite the annoying sound...
Old May 10, 2009 | 12:37 AM
chernmax's Avatar
Totally agree but you only notice it more when outside the car. Seems once the car gets going the sound tapers off. I also added some Ultimate-B quiet under the back seat. It helps!!!
Old May 10, 2009 | 04:57 AM
yea but the thing is i really dont hear it when i try to listen to my seat.... if that makes any sense? i thought about dynamat like you did but it doesnt seem to be coming from there. i really hear it more towards the front of my car during idle, while im driving the exhaust note usually drowns out the noise.
Old May 11, 2009 | 05:05 AM
chernmax's Avatar
I hear mine more towards the rear, sounds like the jet engines on the batmobile spinning up. I've gotten used to the sound though...
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
aminus21
Sep 12, 2015 04:53 PM
