will CAI pass inspection
well friendz keep sayin cuz itz aftermarket i might not pass...by da way my friendz all drive crx or hatchback civ'z nd go 2 some place pay a guy 2 pass them. is this juz a reason 2 get caught nd have no car or should i go this route lol
You need to do some research and find out what they check for. Go there and ask some questions before you actually want your car inspected. That way you can make corrections w/o having to go through the hassle of failing.
^^^ like he said
YOU really need to find out what your state does, for example Maryland is much more focused on the emissions test. meaning they really care more about the output of the car and that its not straight up killing the environment. That being said other states have visual tests, where they look in and around your car for any aftermarket or broken/ mis-treated OEM parts. Then some do both.
If it were me id ask someone i know that does not go the route your buddies with the civ's and crx's and find out what they really do in your state. Or research but anyway go in prepared and not totally unaware of what will happen. The emission test is a state law so it should not be hard to find on the web. Good luck
You shouldn't have any problem. Assuming you drive an 08 by your s/n you only go for safety inspection which I believe is only $10 unless it went up... they only check things like horn and lights etc. Further more any modern OBDII car they basically check the safety stuff and then look for a check engine light and plug your car into the computer. The days of the smog test and putting our cars on the dyno is a thing of the past, the DMV reads your computer to check for codes and stored values. Most places in the BX don't even check anything but the computer, I just got mine done on Thursday and that's all they did... Pm/IM me if you wanna know where to go.
Im glad NY dropped that stupid dyno machine
Mar 12, 2020 12:06 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
