steering fluid change
Old Nov 16, 2008 | 12:12 AM
rick sambora's Avatar
I need some info regarding the steering fluid flush/change. I was told that my PS fluid was dark and dirty and needed a change. I was surprised as I just have 46k on my car. However, it did smell burnt. I have been searching the forums for a sticky or instructions. I could not find anything specific for our gen. Is there a write up here that I am missing? A link to that will be appreciated. Any help from someone who has changed their PS fluid is also welcome. Also when do you guys change your PS fluid?
Rick
Old Nov 16, 2008 | 12:41 PM
redls1's Avatar
MAXIN' ON
Have you cheked the fsm. Lots of info?
Old Nov 16, 2008 | 03:34 PM
Nietzsche's Avatar
It's easy, suck out fluid, fill up with flush, start engine and turn wheel lock to lock a few times. Repeat three or four times and put power steering fluid back in.
Old Nov 16, 2008 | 03:44 PM
STARR's Avatar
Just use the turkey baster method, suck out the master reservoir and refill every oil change or every other oil change
Old Nov 18, 2008 | 11:34 AM
rabit's Avatar
Good info, Thanks Starr. What type of power steering fluid do you guys use/recommend?
Old Nov 18, 2008 | 12:07 PM
STARR's Avatar
You Welcome for the 6th Gen Maxima the Power Steering fluid is just Power Steering fluid, I bought 2, 8 ounce bottles of Valvoline Power Steering Synthetic blend, it was 3 dollars a bottle but it beats the $100 plus the dealer wants
Some Maximas and other Nissan can take ATF for the Power Steering but just use what is recommended
Old Nov 18, 2008 | 10:03 PM
Solow1's Avatar
really u just put that in??
i need to put in some steering fluid as well but i was told that nissan uses j blend or something, cant rmr as of this moment!
Old Nov 19, 2008 | 06:16 AM
Kryogen's Avatar
*4: For Canada, NISSAN Automatic Transmission Fluid (ATF), DEXRONTM III / MERCONTM or equivalent ATF may also be used.
From the service manual.....
I just used regular ATF
Old Nov 19, 2008 | 08:33 AM
rabit's Avatar
wow Kryogen. I was good with the valvoline from Starr but now you make me worry lol. Is the Valvoline an equivalent ATF?
Old Nov 19, 2008 | 11:17 AM
STARR's Avatar
just look in your owners manual under recommended fluids, I was told by 2 dealers not to use ATF, I checked cause several members on this board said they used ATF but in my 06 manual it says Genuine Nissan PSF or equivalent
Old Nov 19, 2008 | 11:20 AM
STARR's Avatar
your not in canada
lowpost99
Oct 26, 2025 06:53 PM
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
pktaske
Sep 4, 2015 08:40 AM
coasterswim
Sep 2, 2015 07:43 AM
