Brake Upgrade
Old Mar 17, 2009 | 10:05 AM
eK9aT10pSi's Avatar
Brake Upgrade
hey guys, i bought the complete rotorpros brake kit with hawk hps pads and ss brake lines a while ago. spring break is now so i figured i finally get these installed [and for my other thread, get an exhaust sound clip].
my question is what is the order to bleed the brake lines?
3rd 4th
0------0
0------0
1st 2nd
Old Mar 17, 2009 | 10:35 AM
DeusExMaxima's Avatar
RR, LR, RF, LF
Old Mar 17, 2009 | 10:38 AM
MAX2DAMAX's Avatar
make sure you pump the brake several times before you open the bleeder valves, and disconnect the abs module too.
Old Mar 17, 2009 | 03:45 PM
Shoey1's Avatar
longest brake line to shortest brake line. like Dues said most cars are RR, LR, RF, LF.
Old Mar 17, 2009 | 06:32 PM
Kryogen's Avatar
How/where do you disconnect the ABS module
Old Mar 17, 2009 | 08:06 PM
My-Body-Is-Ready's Avatar
cute diagram. and yeah what dues said
Old Mar 17, 2009 | 09:18 PM
eK9aT10pSi's Avatar
lol, it wouldve looked better if it didnt autodelete whitespace, lol. so pretty much i had it backwards. thanks guys! ill make sure to post pix if anyone wants to see, lol.
4th 3rd
0------0
0------0
2nd 1st
Old Mar 18, 2009 | 08:18 PM
thealliance43's Avatar
i put on my rotor pros with the hawk pads... is it recommended to bleed your system or is that just because hes got the stainless steal lines?
Old Mar 18, 2009 | 11:12 PM
BLACKNESS MONSTA's Avatar
Exhaust clip is more important
Old Mar 21, 2009 | 10:38 PM
eK9aT10pSi's Avatar
hey guys, finished the rotors, pads, & ss brake lines install!! as an extra, i also installed 15mm wheel spacers too!!
now to my problem, i bled my brakes pass rear, driver rear, pass front, & driver front. it seems that the car still isnt stopping like it should [i know its subjective but i mean at least better than stock]. i bled each wheel at least 20 times.
and my other problem is that with the spacers, the rear rubs when you go over speed bumps. i am assuming my options are roll the fender or cut out that inner lip. what do you guys suggest?
thanks again!!!
p.s. pix up soon.
blackness monsta, sorry for the delay, stil trying when i get a chance; finding someone to borrow their vid cam is a PITA.
thealliance43, yes, its b/c the ss brake lines. if you just did the pads and rotors, you dont have to but you may as well imo, not too much extra time. its good cause it purges out some of the fluid and maybe some air pockets as well.
Old Mar 22, 2009 | 02:11 PM
Kryogen's Avatar
Imo the max brakes feel mushy all the time, I dont know why... my mom's 2002 sentra braked way beter.
If therte's no more air in the lines, it wont get better by bleeding...
9. Bleed the brake hydraulic system air bleeder valves in the following order:
Right rear brake ->Left front brake ->Left rear brake ->Right front brake
Old Mar 22, 2009 | 02:24 PM
mightymax5's Avatar
Hello! I want to buy f/r vented rotors for my 05 max and see a set 2007-2008 from rotorpros will these fit ? Can someone tell me the right part number and what they paid with hawk or axxis pads? Is there a ceramic brake pad option as they tend to have less brake dust? I have to get these ASAP as my brakes and rotors are just starting to lightly grind.
Old Mar 22, 2009 | 03:58 PM
eK9aT10pSi's Avatar
kryogen, i did the order a different way from what ppl told me earlier in the thread, pass rear, driver rear, pass front, driver front.
mightymax5, id email rotorpros, just tell your year, make model and what you want and he'll make u a deal. i went with the hawk hps pads. also, i got the ss brake lines.
Old Mar 22, 2009 | 06:07 PM
mightymax5's Avatar
rotors
The rotors you bought are they vented?
Old Mar 22, 2009 | 08:04 PM
STARR's Avatar
How do the brakes actually feel, pedal feel, now take it on the highway at night, or whenever there is no traffic and take it up to 60-80 and stand on the brake, bring it down to 30 and repeat like 5 times
Bed the brakes in, your rotors should have a bluish glaze or sparkle, which is the brake pad grabbing the rotors
edit: forgot to mention, when you do brakes and you take it for a spin the car feels like it's not stopping, it's a lovely feeling but it will pass and the brakes improve with every mile, give it some mileage but bed the brakes in properly
Old Mar 22, 2009 | 09:55 PM
eK9aT10pSi's Avatar
mightymax5: yes, they are xdrilled & slotted. the fronts are vented and the rears are solid.
starr: i feel a difference but i there might still be some air or not enough fluid. when i press the pedal, its like a pssshh sound. for breaking in the brakes, ive always heard you should drive normally and not too hard for ~250 miles or so to let them break in, i.e. hot/cold cycling so they dont glaze.
i also noticed that as well as i was driving more it felt better [i felt that was subjective so i threw that idea out] that it was maybe stopping quicker. no more vibration when braking!!!
on another note, pos oem rotors were apparantly warped.
Old Mar 22, 2009 | 11:44 PM
whitem1ke88's Avatar
Uhh you guys sure about the bleed order? My nissan service manual says Left Rear, Right Front, Right Rear, Left Front
Old Mar 23, 2009 | 07:38 AM
Kryogen's Avatar
I gave you whats written in the nissan factory manual for the 04 max. Probably wont make a difference anyway, but just so you know.
Old Mar 23, 2009 | 01:23 PM
eK9aT10pSi's Avatar
i guess i am going to redo the bleed order then this weekend. by any chance, if you don't mind, what page is it on? again, thanks for the updated info. maybe that's why its feeling funny.
Old May 12, 2009 | 10:26 PM
eK9aT10pSi's Avatar
update: let the breaks brake in for a bit. the stopping power seems worse than stock. on a side note, ive read before that the ss lines can be the culprit. only thing i dont know is how to test to see where the problem may be coming from. any ideas? TIA
Old May 12, 2009 | 10:53 PM
What type of brake fluid are u using? DOT 5?
Old May 13, 2009 | 03:33 AM
CanadianMoFo's Avatar
When I added just the SS lines the pedal feel improved. It firmed it up quite a bit.
CM
Old May 13, 2009 | 08:14 PM
addicted2pain's Avatar
I am thinking about getting a set from rotorpros as soon as I can fit them in the budget. I am curious if the gold or black zinc plating wears of quickly. Is there enough plating thickness for the color to stick around for awhile?
Old May 13, 2009 | 08:45 PM
it sticks around for about a month or two... then it goes... my brakes are kinda mushy but my girls altima coupe brakes like a dream... and she just has stock rotors and brakes... don't really know why the maxima doesn't brake like that
Old May 13, 2009 | 09:41 PM
My Maxima has always has mushy feeling brakes. I have 300zx tt calipers and Hawk HP+ pads with SS lines its still mushy. Go figure.
Old May 13, 2009 | 11:02 PM
eK9aT10pSi's Avatar
i am using valvoline synthetic brake fluid. i believe its dot3
Old May 13, 2009 | 11:57 PM
I was talking to my mech about brake upgrades and he said u wont truly feel much difference unless u go with DOT 5
Old May 14, 2009 | 04:27 AM
Kryogen's Avatar
The max brakes are mushy and I hate it but what can we do anyway
Old May 14, 2009 | 09:19 AM
Oolatec's Avatar
Mine aren't mushy at all.
Old May 14, 2009 | 01:57 PM
VigilanteMax's Avatar
Wouldnt do this as dot 5 way out of our cars necessity due to its high temp tolerance and also very hard to bleed these. not recommended for ABS. No reason to go above dot 4 in any car on the street, however I have the valvoline dot3-4 synthetic and mine work fine. I also have the 300zx TT and have to clean them regularly due to my slotted rotor eating my pads up.
Old May 14, 2009 | 04:09 PM
eK9aT10pSi's Avatar
i used to use valvoline syn brake fluid but autozone stopped selling it and this was the alternative.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
