04 max 6 spd man transmission reverse shift problems
Old Jun 15, 2009 | 06:56 AM
Galto2000's Avatar
Hello all
I have a 04 max manual 6speed with 86K miles on it.
Since recently I often (not always) happen to find myself in the 6th gear instead of reverse in my attempts to back up my car. At first I thought I was just my mistake. But after it happening too often I realized that it is my gear box or transmission that seems to be acting up.
During those moments, I noticed that after I pull the reverse lever on the stick and put it into reverse, the stick seems to make contact with "something that didn't use to be there before". Using my normal arm force at which I move the gear stick this “apparent obstruction” causes my gear to move in the 6th gear instead of the reverse.
When I consciously exert more shifting force then this “apparent obstruction” seems to "move aside", with a clicking noise which I also can feel as an impulse in the palm of my hand through my stick as it moves into reverse.
It doesn't happen all the time though. For example, when I go to the dealer's mechanic, and he tries it, it works normal (typically ). It happens sporadically and typically at moments when you are not looking for it.
Anyone has any ideas what might be going on? Anyone experienced this too?
Cheers,
G
Old Jun 23, 2009 | 01:40 PM
rk_KC9ball's Avatar
I am having exact same issue with my 04. Mine started doing it at about 86 K as well and is now seemingly getting worse. I am at 91K now. Did you find out what was going on by chance?
Old Jun 24, 2009 | 11:32 AM
rk_KC9ball's Avatar
bump
Old Jun 25, 2009 | 04:44 PM
04MAX_ILLIN's Avatar
Maybe the mechanism that "unlocks" when you pull the ring up on the shifter and try to shift into reverse is broken/loose ??
Old Jul 6, 2009 | 06:01 AM
rk_KC9ball's Avatar
Galto- Not sure if you may be having the same problem but I was able to back the shift **** off unthreading one complete turn and my problems are gone. I found that when I pulled the shifter boot off that the mechanism simply wasn't pulling the "lock" up high enough. Hope this helps.
Old Jul 6, 2009 | 09:04 AM
kamski's Avatar
.org extraordinaire
G
Undo the shift **** one turn.
PROBLEM SOLVED.
Old Jul 8, 2009 | 05:52 PM
rk_KC9ball's Avatar
PROBLEM SOLVED.
Guess I could have said it that way....instead of my babbling nothingness... I suck
CorollaULEV
30
Aug 9, 2021 08:11 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MikesChevelle
Aug 14, 2015 12:31 PM
Trin1j23
Aug 12, 2015 08:31 PM
