stillen rear valence
Old Jul 12, 2009 | 09:24 PM
6thGenSmoke's Avatar
i installed this yesterday using 3m double sided tape and today i noticed that around the curves that it isn't sticking very well and seems to be coming off. the sides and center are fine and are on well. did any of you guys have this problem when first installing it? is it something that i am doing that is causing it? thanks in advance
Old Jul 12, 2009 | 09:33 PM
JAMAICANLOVRBOY's Avatar
did you clean it really clean, if not it wont stick well. you can also run a small screw through it to help secure it better. or you can take it a step further and get it molded in so it looks like a part of your bumper
Old Jul 12, 2009 | 09:48 PM
its cleaned well..installed it right after washing the car. i dont want to mold it. the front lip install was fine.
Old Jul 12, 2009 | 10:04 PM
to be honest 3M double sided tape to intall that thing wont work unless you put a couple screws in there, or just mold it. and if it did, it will only work temporarily. almost everybody i know with the stillen rear valence, use something with the double sided tape simply becuase unlike the front, the rear has nothing to hold on to.
Old Jul 12, 2009 | 11:26 PM
2theMaX05's Avatar
Sorry but you dont use screws only on the bottom center of bumper ,3m tape adhesive sticks on very well. Had mine on thru last winter and steady rain days and still no problem. You have to properly clean the bumper and spoiler prepsol usually works and you also need a heat gun to heat up bumper and spoiler . If done right you shouldnt have a problem...
Old Jul 13, 2009 | 12:24 AM
blaxima06's Avatar
I say contact MaxJ04, he had the same problem.
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
Maxboy23
Sep 4, 2015 06:04 PM
