Help!! How do I clean corrosion off female/male connectors?
Old Jul 19, 2009 | 01:47 AM
2LEET4U's Avatar
One of my LED tail lights is having problems.
4 months back, a car hit my parked Max... Insurance fixed the damaged and replaced 1 of my LED tail lights.
Now it looks like that same tail light has NO brake light or turn signal light.
I removed the tail light and the dumb *** mechanics didnt insert the 3 connectors into the tail light housing. So the wires were hanging lose.
I noticed green corrosion around and inside the female and male connectors.
I dont believe the lights are Fragged! Because they still turn on. But when i break, the light goes off.
I think i just need to clean the green corrosion off. Is there spray or liquid i could buy to clean the connectors??
Old Jul 19, 2009 | 08:07 AM
KCMAXX's Avatar
KC's FINEST
http://tinyurl.com/m564f5
Originally Posted by 2LEET4U
Old Jul 19, 2009 | 01:37 PM
2LEET4U's Avatar
Originally Posted by KCmaxx
uhhh... yeah i did that already and from Mr. google's vast knowledge, i only found this:
Mr. Google - "A stiff tooth brush, a cut paper clip and spray cleaner after fixxed my funky brake lights."
I figured someone would know what kind of spray cleaner to user and if someone would say the same thing...
But good bash though!!! LOL
Old Jul 19, 2009 | 02:02 PM
KCMAXX's Avatar
KC's FINEST
Try dipping the ends in coke. (Cola)
It works great on battery corrosion.
Old Jul 19, 2009 | 03:49 PM
MikAus's Avatar
CRC ELECTRONIC CONTACT CLEANER
best stuff, comes in a red spray can
Got mine from ACE hardware.
Try it, you will not be dissapointed and will not mess up your contact plugs.
Old Jul 19, 2009 | 05:10 PM
xoomer.com's Avatar
I Donate! Why Don't You?
walk into RadioShack and they have exactly what you're looking for.
Old Aug 6, 2009 | 03:51 PM
wickedmax13's Avatar
A potent combination of baking soda and warm water do the trick on a car battery...it would probably do the trick on a connector.
Old Aug 6, 2009 | 07:12 PM
papasuede's Avatar
use some sand paper on the connections, or a sharp exacto knife or blade to scrape the corrosion off of the metal. Then treat with corrosion resistant grease.
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
