FINALLY fixing timing chain noise!!!
Old Aug 13, 2009 | 08:11 PM
Y2k2maxse's Avatar
so the dreaded timing chain noise became CONSTANT a few weeks ago..and I thought my baby was gonna be done. Well she stood up to 75,000 miles of timing chain problems and STILL ran smooth (at 142,000 miles) but anyway I took it to my mechanic he took it apart and saw that one of the bolts that holds the upper timing chain guide in came loose..finally came out all the way..and the guide metal actually broke off probably from vibrations and hot and cold so much...and ..fml..i went and bought all chains..tensioners..water pump etc, and it was an $11 guide, I am also gonna replace the outer full cover on the side of the engine which is like $100..so I have no leaks. All in all she'll be good as new and some of you I suggest having your mechanic at ;east romove the side cover to look at what youve got there because it might be an easy fix to the noise (im surprised the bolt or metal piece didnt get caught in the chains and break them...
Old Aug 13, 2009 | 08:24 PM
slvrmax7's Avatar
Wow- very interesting to finally see the culprit ehhhhh!? How much is this total fix btw!?
Old Aug 13, 2009 | 08:34 PM
Y2k2maxse's Avatar
well..considering i did NOT need all chains and tensioners water pump etc it would have costed $11.97 for the guide..and the labor will be around $500..but I spent $413 on parts that didnt need to be changed..just figured I would while im in there. Why not.... they got 140,000 miles of wear on them.
Old Aug 13, 2009 | 08:35 PM
Y2k2maxse's Avatar
and yes VERY interesting to see it...i could not WAIT to see what it was. Next week will be the first time since ive had this car that I will hear it run NORMAL and QUIET on startup....I am PSYCHED!!!!!!!!
Old Aug 13, 2009 | 08:55 PM
slvrmax7's Avatar
Yea good point I'm sure I will go that route and replace all those miscellaneous things when I reach this problem, hopefully it's a long way off as I'm at 75k with half of that being literally all 65-70MPH highway driving. Anyways, let us know how she sounds when you hit the streets again!
Old Aug 13, 2009 | 09:03 PM
Y2k2maxse's Avatar
if u dont have this prob now u may never have it. i hope you never do!! always check your oil level..keep it full.
Old Aug 13, 2009 | 09:34 PM
slvrmax7's Avatar
thx for the heads up, I really should check it more often!
Old Aug 14, 2009 | 02:05 PM
hey11101's Avatar
Mine makes the noise on start up at 135K what is the risk if I do nothing about it?
Hondarydr
Dec 30, 2024 06:15 PM
maxinout93
Oct 27, 2015 01:29 PM
Starrider
Sep 17, 2015 07:26 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
maxinout93
Aug 16, 2015 07:25 PM
