Repeat Blown Fuses, Please help
Old Aug 28, 2009 | 12:00 AM
aaroncv's Avatar
Hey Guys,
Need a bit of help on this one. I was on the highway last week when all of a sudden everything went dead, steering, complete dash, & car completely shut itself off just rolling forward in neutral out of the friggin blue! upon looking under the hood a buddy and I discovered I had blown a fuse. [Pic below] Green box, 40A fuse which seems to control the engine. Once we bridged the fuse it started up so we simply replaced the fuse. A few days goes by and I swear I hear clicking noises coming from the steering column similar to that of static cling. I brushed it off thinking it was by keys banging against one another. Well sure enough today when I started my ride this afternoon I began to turn the wheel, hear the static cling noise & boom..... car dies again! Argghhhh!!!!!
I pop the hood only to find the SECOND fuse below it blew as well. I Then soldered the two fuses together to get her home. It worked to start it up, but then I noticed the steering column started sparking up! Smoke & fumes started coming from the pedals area. this would happen whenever I tried to turn the steering column so I had to stop her and load my baby onto a flatbed to get her home .
Any thoughts as too what could be the issue? Only mods are a Pioneer Avic-D3 (installed about a year and a half ago... oh yeah I didn't have the PAC steering wheel unit installed if thats what anyone was wondering. So the steering controls are dead to the world & shouldn't be playing a role here.) LED Luxer 1 lights (installed about a month ago).
Old Aug 28, 2009 | 05:17 AM
ddelaud's Avatar
what fuses are blowing? what im not sure, but something shorted out in the steering column. maybe the ignition switch??
Old Aug 28, 2009 | 02:34 PM
RandyZ's Avatar
I'd check the steering column for sure. If it was sparking and smoking you should be able to quickly see where the problem is. Probably chaffed(?) through a wire and its shorting out.
Old Aug 28, 2009 | 03:30 PM
aaroncv's Avatar
Thnx guys, yea it actually turned out to be the steering wheel column & some wiring of the after market alarm as well. I brought it to the stealership and they said it's not friggin covered cuz the alarm was installed "after". I nearly blew my own fuse when I told them I purchased it from Nissan with THIS very alarm installed in it. (Car was pre-owned). Long story short... I have to flip the bill for it. :|
Old Aug 28, 2009 | 03:52 PM
HMAX08's Avatar
man i would make more of a stink because they sold it to you wiht that alarm. was it certified pre-owned? i would ask to speak to the manage's manager, put up a little more stink see what happens, call corporate and file a claim, it may not get you anywhere, call BBB and make a claim. Tell the manager that you are going to do all this if they did not fix all. See what happens, dude be an ahole, b/c it aint right and we all know it
Old Aug 28, 2009 | 04:08 PM
nyana107's Avatar
^ what he said. if you bring it up most likely they'll give you the run around but if you keep pushing on the matter and be an a-hole, things will most likely go your way since you're right. you bought the car from the dealership with that alarm already installed so it's their default from what i see.
leatherneck
Sep 30, 2015 09:16 PM
conansriver
Sep 16, 2015 12:17 PM
Maxie40
Sep 14, 2015 11:28 AM
jwright36
Sep 8, 2015 11:45 AM
