Spare Tire
Old Mar 21, 2010 | 11:14 PM
eK9aT10pSi's Avatar
Spare Tire
Hey guys, this is probably a simple question to answer. For the ppl that opted to have an 18" spare instead of the donut, does it go facing up or down and is the cover a different part? TIA
Old Mar 22, 2010 | 03:05 PM
DAlastDON's Avatar
I am not for sure but i think side that the lug nuts go on faces up.
I dunno if i even have a spare. If i do then i dunno if it even has any air. Since i will never see it, i really dont care . Roadside assistance FTMFW.
Last edited by DAlastDON; Mar 22, 2010 at 03:08 PM. Reason: Had to make it rhyme :)
Old Mar 22, 2010 | 07:19 PM
sensfan1111's Avatar
I have a full size spare and it is facing down, this way you can put an extra jug of washer fluid or liter of oil inside the rim and still have the cover fit properly. I'm sure that the cover is a different part than those with just the donut. My cover bulges up about an inch around where the spare is to give it clearance.
Old Mar 24, 2010 | 11:05 AM
eK9aT10pSi's Avatar
when u got ur maxima, did it come facing up or down? also, since urs is facing down,did u have to remove the center cap? yeah, i was wondering too i have it facing up and the cover bulges.
Old Mar 24, 2010 | 12:10 PM
MadMax07SL's Avatar
Full sized spare...I'd love to see a picture of that!
Old Mar 24, 2010 | 12:28 PM
the macedonian's Avatar
+1 on that bro - CAA(AAA) FTMFW
Old Mar 24, 2010 | 06:53 PM
It was facing down. There is no center cap as the rim is secured to the bottom of the trunk with the plastic piece threaded in to the the bottom of the trunk. In the event you need to use the spare, you would take the center cap off the tire that is flat so that you can secure the flat back under the trunk cover.
Old Mar 24, 2010 | 07:01 PM
I will try and get a couple tomorrow, it's too dark to get any now...
Old Mar 26, 2010 | 10:28 PM
eK9aT10pSi's Avatar
ill do the same this weekend for u guys if it doesnt rain. since i got new rims, i had the oem ones so i kept the nicest one and made it to a spare.
hopefully face down, it wont create a hump in the middle anymore
Old Mar 26, 2010 | 11:54 PM
DeusExMaxima's Avatar
Get rid of the spare and save weight so u can go faster FTMFW!!!
Old Mar 27, 2010 | 11:45 AM
Finally got some pics for you guys...
Full size spare
Spare tire cover
Trunk liner
Old Mar 27, 2010 | 12:08 PM
SiathLinux's Avatar
In my 4th Gen - there is a bracket that sticks up - so I can't put a tire in 'face' down, also, my cover is 'flat' (bit bowed at the moment) so if I put a full size spare in the space it wouldn't touch steel the whole way around...
But this is in my plans - create a 'false' bottom in the rest of the trunk in order to have a flat trunk bottom with a full size spare in place.
Ryaliu's Avatar
Have you tried flipping the board?
Old Mar 27, 2010 | 12:46 PM
A full size spare face up or face down will always create a hump in the middle, which is caused by the width of the tire. The only way i can think of getting rid of the hump is to do what Deus suggested:
And then flip the board.
Any one out there with just the donut for a spare have the hump in the middle?
Old Mar 27, 2010 | 11:28 PM
eK9aT10pSi's Avatar
originally i had the donut in there there was no bump
sensfan1111, it looks like u have the SL full size spare. in my OP, im talkin about the SE 18" oem full size spare. weathers been **** so i cant get outside to take pix at the moment.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
JonBlz
Oct 5, 2015 06:02 PM
Garrettz459
Sep 28, 2015 02:50 PM
