tie rod end
Old Mar 29, 2010 | 08:51 PM
240tomax's Avatar
tie rod end
Have an 06 with 57 k. When changing over to the summer tires I discovered I need a tie rod end for the drivers side. How long should it take me to r&r, and what usually causes the tie rod end to go.
Old Mar 29, 2010 | 11:40 PM
NIKV69's Avatar
It's real easy to do. Under an hour. How do you know it's bad? As for why it went so prematurely hard to say, driving habits, defective part.
Old Mar 31, 2010 | 08:11 PM
mymaxma's Avatar
hmmm are you sure its tie rod? i was told i needed inner tierod but once apart it was the rack & pinion ironically it took failing inspection to bring this problem to attention it was subsequently the problem i had from vibration/shimmy that went ignored by Nissan for years! i was told it was a definate tierod and it was definately not..... just double check to be sure although the tierod is very inexpensive in comparison to the Rack & pinion assembly.
Old Apr 1, 2010 | 03:33 PM
240tomax's Avatar
No vibration/shimmy at all. When the car is suspended on lift, there is a bit of play in the wheel when you attempt to push wheel in and out.
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
BobTX10
Oct 7, 2015 08:43 AM
Sep 27, 2015 08:37 AM
