wheel studs
Old Apr 4, 2010 | 03:21 AM
chric147's Avatar
wheel studs
I broke 2 studs on my max I was wandering if anyone has replaced them and how to do it and what I have to take off I can get to take the rotors off but I do not know where to go after that.
Old Apr 4, 2010 | 05:06 AM
KCMAXX's Avatar
KC's FINEST
Take the wheel off, remove the two bolts holding the rotor onto the hub, take the rotor off and tap them out the back with a hammer.
The new studs are 45mm I believe with a 12x1.25 thread pitch.
Old Apr 4, 2010 | 07:32 AM
Scott D.'s Avatar
Putting the new ones in is the fun part. You really need an impact wrench. Use a bunch of washers as a spacer and tighten up the lug nut until it seats against the back of the hub. I did it with a breaker bar, but you have to have someone help you and hold the hub from spinning with a crow-bar. make sure and put lugs on the studs you pry against so you don't damage the threads.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
Redfox
Sep 28, 2015 10:41 AM
