wanna go LED...
Old May 5, 2010 | 07:13 AM
ikalinin's Avatar
wanna go LED...
hey guys. so I wanna go LED in the rear tails stop/parking/turn.. everything as well as the front. Before I buy, I have questions...
1. load resist req'd for each LED... where do you mount them ?
2. turn signals LED... cant we just get a different relay flasher and it'll fix it
throughout the entire car?
any help is appreciated. Thanks
Old May 5, 2010 | 09:02 AM
Jammmaxx's Avatar
You just need the resisters, 2 to be exact. You mount using the wiring from the turn signal bulb in the rear. There is a write up on here somewhere as to how to go about doing it. Its real easy. PM me if you need help.
Old May 5, 2010 | 09:38 AM
aznstormin's Avatar
Resistors required only for the turn signals. The stop/reverse/parking leds, just switch them out.
Old May 5, 2010 | 09:58 AM
BOOTZ's Avatar
From what I understand.
You need two 3 ohm 50 watt resistors if you are doing both front and rear led turn signals.
If you are only doing rear or only doing front turn signals, then you will need two 6 ohm 50 watt resistors.
One resistor for each side.
Correct me if I'm wrong anyone....
Old May 5, 2010 | 12:28 PM
jsmithsole's Avatar
*moderator*
Correct 2 3ohm (One on each side covers front and rear) load equalizers and mount them in the rear so they are out of the way.
Here's the write up i did a few years back. And remember always check the stickies first!!!
http://www.vqpower.com/v2/articles.php?article_id=120
I never mounted mine, they hang down below the taillight and don't touch anything, they get very hot...
Where are you planning on buying lights from BTW?
Old May 5, 2010 | 04:43 PM
KCMAXX's Avatar
KC's FINEST
My stock tails without brake lights...
LED bulbs installed, still no brake lights.
Old May 6, 2010 | 07:21 AM
ikalinin's Avatar
nice.. for some reason, when i had LED bulbs in my maxima (03), they were nice and all, but you couldn't really really tell the difference when the lights were on and the brake was pressed.. like it lit up a little, but not really noticeable.. so i wonder if i had the wrong bulbs or what not...
Old May 10, 2010 | 05:55 PM
mrkhone's Avatar
nice. what kinda bulbs do u have in there and where can i get some
Old May 12, 2010 | 01:14 PM
jsmithsole's Avatar
*moderator*
www.autolumination.com 3157 red bulbs for the tails. Pick your style...but make sure they have side facing LED too to reflect the light.
These will work GOOD: 60 High Powered Wide Angle SMT LEDS
KC has these that he got form me, a bit older style but still good!
18 Wide Angle Oval LEDS
Old May 12, 2010 | 02:46 PM
nickelbn1's Avatar
leds
so, you can buy led lights that will directly replace the OEM tail lights but you have to install a resistor? or just on the turn signals you have to install them, and all other lights you can just swap out?
Old May 12, 2010 | 02:50 PM
stockmaximaFTW's Avatar
NOT INVITED TO MAXUS 2010
if you don't mind paying 30 bucks per light they are an awesome buy.
Old May 12, 2010 | 06:26 PM
mrkhone's Avatar
so if i just wanna do the brake and parking lights i won't need the resistors? thats all i want to do.
Old May 13, 2010 | 05:46 AM
KCMAXX's Avatar
KC's FINEST
If you're going to do the parking lights, I would assume you mean the fronts. If so, then yes, you would need resistors.
Shortly after installing mine, I added 72 LED's to my third brake light.
I really feel sorry for people behind me now...
Old May 13, 2010 | 05:57 PM
mrkhone's Avatar
i mean just the taillights.
Old May 13, 2010 | 07:22 PM
BadBlackMaxSL's Avatar
KC.... Hello Kitty??
Like the LEDs too.
Old May 13, 2010 | 08:17 PM
KCMAXX's Avatar
KC's FINEST
Like the LEDs too.
I have two daughters bro...
Old May 21, 2010 | 05:04 PM
NismoMax80's Avatar
SuPeRmOd
Just ordered $200 in leds for my tails O.O
but that's 20% off for the brightest 10 bulbs out there, resistors, backing plates, and shipping.
V-LEDS.COM | LED Dome, Map, License Plate, Reverse, DRL, Turn Signal, Brake Lights
let me know if you want the short 20% off code. i got it for joining them on FB
they even have swtichbacks, but i like my chrome blink only filament bulbs for up front.
Old May 24, 2010 | 02:46 PM
farzin1's Avatar
The bad thing about LED's is that once they burnout they will look like **** tho
Maxboy23
55
May 1, 2025 06:09 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
I<3 A32's
Sep 10, 2015 11:07 AM
