Brake and Battery Light Flashing-Alternator?
Old May 12, 2010 | 11:48 AM
bmckendr's Avatar
So my brake and battery lights started flashing last night. They flash on and off, at the same time, at random. Then they stay on for awhile solid, then go away and flash intermittently again. Everything Ive read so far has said this is the death toll of my alternator, but that has all been for 4th Gens. I have a 2004, but Im assuming same deal right?
Anyone else have this happen, thoughts?
Also, I was just about to bring in my car for the timing chain tensioner replacement as you can hear the characteristic high whine when reving that is in all the videos, and I've seen on a lot of peoples posts when theyve gone in to have that problem fixed, the dealer often misdiagnosis it as a bad alternator? Think I'm gonna have a problem getting the tensioner fixed since I do have a bad alternator (potentially)? Suggestions?
I have about 3500 miles left on my extended warranty
Old May 12, 2010 | 04:12 PM
bmckendr's Avatar
Update: mustve been the alternator as my car just died
Old May 12, 2010 | 05:58 PM
NiZMo1o1's Avatar
yup ALT is done !
Old May 12, 2010 | 07:00 PM
BOOTZ's Avatar
That sucks. Definitely the alternator.
Old May 12, 2010 | 07:08 PM
bmckendr's Avatar
Pardon my lack of knowledge, but why would dealers diagnose the timing chain tensioners being worn as a bad alternator? Is it possible the whine I heard, which sounds like every tensioner video I've seen posted, was just my alternator? I want to be prepared for a possible fight with the dealership. I noticed the whine in march, but don't know how long its been there....
Old May 12, 2010 | 07:10 PM
NiZMo1o1's Avatar
well you should have had autozone or advance check the battery or charging system for free of charge.
since those lights came on then its your ALT gone.
Maybe Nissan wanted to make some money off you
Old May 12, 2010 | 07:12 PM
BOOTZ's Avatar
Yea, I heard a wine right before my alternator went. Almost sounded like I had a supercharger before it went. lol
Not sure what it would sound like when the tensioners are worn.
Old May 12, 2010 | 09:44 PM
Oolatec's Avatar
Worn tensioners would be a metal ticking/clicking noise that goes to a higher pitch if you hit the gas, making the chain spin faster.
The alternator is just that, a whine. Way different if you've ever heard both.
I had to replace the alternator on my '04 at around 40,000 miles. Out of warranty of course. Blah.
Old May 14, 2010 | 06:33 PM
bmckendr's Avatar
Ok thanks. I just got the alternator replaced, just gotten paranoid over the tensioners as it seems this is a problem that WILL happen, not MIGHT happen. The videos Ive seen of tensioner noise from members here I thought sounded like this, but I dont have a metallic clicking, just the whine, which is gone now with the new alternator. Thanks for the input
Old Jul 19, 2011 | 06:07 PM
tburdette743's Avatar
I have a 2004 Maxima SL. In summer of 2009 it just would not start one day. I put a battery on it first then it died a few days later so I put an alternator on it. The brake and battery light had been on prior to this but I wasn't sure if that was normal or not. Ok it worked fine for almost a year then same problem, the car just lost power and died. I had it towed to a garage,battery and alternator tested ok. they charged the battery and it started and I have had no problems until now almost a year longer now. I was driving up interstate brake and battery light flashing approx 100 miles later it lost power and died. I put an alternator on it and drove it home, it worked fine for a couple of days now the lights are flashing again. I talked to a mechanic that says there is an intermittent problem with Nissans that I may charge the battery back up and not have any problems for a while or it may keep doing it and it would have to be doing it for him to find the problem. I also heard its probably a computer problem. Any ideas? I can't afford to fix it, its gonna take time to save up some money.
Thanks in advance
Old Jul 19, 2011 | 07:07 PM
CXJ Performance's Avatar
Former Sponsor
first fire the mechanic cause hes hosing you. buy a new battery and drive away
Old Jul 22, 2011 | 10:44 PM
spencerwh1's Avatar
This is def the alternator.. Or generator as said in the FSM. Mine did the same exact thing, brake light and battery light started flashing then eventually stayed on steady.. so I replaced it myself. And the only thing that bothered me is the fact you have to remove the radiator, fans, idler pulley.. But its really simple.
Old Jul 23, 2011 | 12:10 PM
Former Sponsor
that alternator bolt is a real ***** as well
Old Aug 21, 2011 | 08:53 AM
markrfischer's Avatar
Pretty sure my alt just went down on my 04 .. Just got done with at long trip with GPS and cellphone charging the entire way. With 150k on it, I think that accelerated the failure. Anyone know a decent place in Indy for the work?
Old Aug 21, 2011 | 07:26 PM
TSMReLL's Avatar
nope dont be so sure to blame it on the alternator alone.. i had a simular issue .. ended up being a short with a ground connection
Old Sep 24, 2011 | 12:09 AM
goldie260's Avatar
2008 maxima brake and battery light comes on
2008 maxima and my brake and battery light comes on and off ,, i was driving in the rain on the belt pkwy in brooklyn heading home i hit alittle water is that a possiablity for it to come on i only have 40,000miles on it
Old Sep 24, 2011 | 02:00 AM
Icons04SilverMax's Avatar
When my alternator crapped out I was around 90k miles and the whole car went into limp mode.
tsi6001
Oct 3, 2022 10:23 PM
homeyclaus
Sep 3, 2015 06:15 PM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
