Replacing motor mounts and have some questions
Old Sep 13, 2011 | 06:33 PM
  #41
Kryogen's Avatar
no **** ur 7 months late man
Old Sep 13, 2011 | 09:18 PM
  #42
twentyeggs's Avatar
hahahahaha my bad
Old Sep 24, 2011 | 12:27 PM
  #43
FenderGuy's Avatar
Car is at the dealer now getting a oil change. Just when I start to fix the little things to get this car sold, the Maxima lets me down again...
Dealer says my front and lower mounts are shot...Seeing that the stealer was going to charge someone $1200 to replace 3 (rip off) Can you still get these mounts for cheap?
Old Sep 25, 2011 | 10:43 AM
  #44
FenderGuy's Avatar
Stealer didnt quote me $1200 only $865 to fix 2 mounts...Sold as soon as possible...
Old Apr 4, 2012 | 08:14 PM
  #45
augiecorrea's Avatar
04 Maxima Motor mounts
Hi I have a 04 Maxima and when I accelerated a little fast from 0 MPH it hits on the bottom and you can hear it by you Feet.
I need to know if the Racinline Motor mount work better and last longer since the 3.5 Engine has a lot of power to damage the mount in a short time??
Please email me at agustincorrea@hotmail.com
Agustin ( Augie) from New Jersey.
quote=Switch;7793344]I just ordered Racingline's moter mount insert sport kit. If you're into performance I would recommend it over factory mounts.
Let us know how the install goes/went!!! Pics?
JB[/quote]
Old Oct 22, 2013 | 05:45 PM
  #46
Les7311's Avatar
Did anyone post any pics how to install the engine and tranny mounts? am considering doing this surgery same....
Old Jul 19, 2014 | 03:41 PM
  #47
mdollazs05's Avatar
Originally Posted by ifti_sit
I have the FSM - let me know if you need them in order to do it yourself. You will save lot of money.
I hear Racingline inserts actually works for many and make engine more stiffer and also the life of your mounts increased. No experience - just what I read in forums.
Can you send me the FSM on the motor mounts please
Michaelpettaway@gmail.com
Thanks!!!!!
Old Mar 21, 2015 | 02:07 PM
  #48
Poeboy23's Avatar
Originally Posted by twentyeggs
yeah man, cut the bolt off, and buy a new one, put it in the other way. solved
if you don't wanna look for another bolt you can try to use your jack and push the engine up with it. or use the stock jack and place it in between the engine and the mount push them apart to get that little extra wiggle room.
You gotta drop the sub frame an inch, take the through bolt out of the front mount, unbolt the trans mount jack it up then that bolt will come right out. I just did it on a 05 SE Maxima.
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
Rage Maximus
Sep 3, 2015 12:26 PM
george__
Aug 18, 2015 07:06 PM
doobadoo
Aug 15, 2015 06:43 PM
