Switchback problems
Old Oct 9, 2010 | 02:06 PM
6.5affiliate's Avatar
Switchback problems
I currently just bought a pair of 60 SMT switchbacks from V-LED and I was extremely happy when they arrived. Once I got them, I immediately decided to install them without the resistors since I ordered them later than the switchbacks. Anyways, I notice now that when I apply the brakes there would be one of two things would happen;
1. Both would turn off until I let go of the brakes.
2. Passenger side turns off while the driver side is still on and visa-versa
Does anybody have a clue about how to solve this problem?
Old Oct 9, 2010 | 02:56 PM
primeval's Avatar
on mine when i brake the right switchback will blink for a split second and when i switch from like park to drive or reverse the left one will flicker. no idea why
Old Oct 9, 2010 | 03:39 PM
TargetPractice's Avatar
I don't know how these work, but I would suspect a bad ground.
Old Oct 9, 2010 | 04:03 PM
DAlastDON's Avatar
Any modifications done to the rear tail lights?
Old Oct 9, 2010 | 09:16 PM
Yeah, I don't know what's the reason either. I just installed the resistors today and reset the ECU. It kind of stopped the problem of it turning off for the most part. Still have a little bit of an issue though. I decided to contact V-LED and see what they say about it.
That might be an issue but it's a direct plug and play so I'm not to sure.....
Nah man.....still on stock tails for now.
Old Oct 10, 2010 | 06:08 PM
I3LAZEN's Avatar
Yea havent heard of this issue before man... lets see what vleds say.
Old Oct 10, 2010 | 11:06 PM
Yeah, I'm interested in their response too. The only issue that I'm having right now is that when I put the car in reverse. The passenger side switchback will go out until I put it back into drive.
Old Dec 22, 2010 | 08:28 PM
BossMaxima's Avatar
I have the same problem with mine that I just installed today. Sorry to bump an old thread but has anyone found a solution to this?
Old Dec 24, 2010 | 07:45 AM
BossMaxima's Avatar
Noone has an answer to this? Ive rewired my resistors 3 times already and I still have the same problems occurring.
Old Dec 25, 2010 | 12:42 AM
maximakid06's Avatar
i had this exact same problem with my switchbacks until i switched my tail lights out for the LED tail lights. Before i changed my tail lights my front passenger switchback would flash when i pressed the brakes and go out completely while in reverse. I used resistors and they helped a little but i was still experiencing problems. I believe when I switched to the LEd tails it equalized the current for the front and rear park lights. Just my theory. I believe the OEM tails were pulling too much current causing the switchbacks to go out when applying the brakes. Try removing the bulbs from your tail lights and see if that solves your problem. If so just but some led bulbs for the rear or get the led tails.
Old Dec 25, 2010 | 07:21 AM
BossMaxima's Avatar
Ok I will definitely try that. So you kept the same 6 ohm resistors correct? Because it would be a really simple fix to order a set of led bulbs for the rear rather than having to replace the switchbacks with regular bulbs again.
Old Dec 25, 2010 | 10:40 AM
DAlastDON's Avatar
If your just changing the bulbs out in the rear tail lights you will have to change out the 6ohm resistors with 3ohm or add another pair of 6ohm resistors in parallel to make the final resistance 3ohms.
If your replacing the entire tail light housing with the LED housing from ezkoncepts then use the same 6ohm resistors. Reason: The ezkoncepts tail lights have a 6ohm resistor in them and they would be in parallel with the 6ohm resistors you currently have thus making the final resistance 3ohms.
http://ezkoncepts.com/led%20tails.html
Old Dec 27, 2010 | 03:32 PM
jsmithsole's Avatar
*moderator*
Weird, I have never had problems, but I always buy mine from Autolumination....
Old Dec 27, 2010 | 07:59 PM
DAlastDON's Avatar
Don't get me started about Autolumination.
Old Dec 27, 2010 | 09:28 PM
BossMaxima's Avatar
I figured out most of my problems were related to a insufficient ground. With my subs and amp and everything else pulling off of my stock electrical system, the ground was not good enough and thats what led to my lights having problems. After grounding the resistors to the sheetmetal, when I hit the brakes the switchbacks dim but nowhere near as bad as before.
Waiting on my other resistor to show up because during the install I somehow lost one . Hopefully the other resistor will be here after I get back from New York.
Old Jan 5, 2011 | 06:21 PM
BossMaxima's Avatar
Tried new resistors, grounds nothing worked. At this point I have gotten tired of it and after emailing V-LEDs multiple times, their only response was to return the leds. So I just ordered some chrome/amber bulbs and the money I get from the return will go back into the Maxima.. So if anyone has any ideas for a really good $60 mod let me know..
Old Jan 6, 2011 | 06:25 AM
the macedonian's Avatar
that sucks bro - i got a good one where you can invest the $60 -->
get some stickers and rice out the car (i heard that each one gives you as estimated 2hp gains to the wheels!!)
in all honesty, I'd take the 60 and add another few bucks and grab either a grounding kit, led tails, y pipe etc etc
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
