Sunroof stopped working!
My power sunroof in my 2004 Maxima SE just stopped working. it will raise up, but it will not slide open. When I move the switch, it just does nothing. Anyone else have this happen? is there a fuse for the sunroof I should check?
the reset procedure is in your manual.
Originally Posted by nickelbn1
(Post 7777687)
I have that happen on occasion....just hold the forward part of the tilt button (the side you press to close the tilt) for about 15 seconds or so and let go...then slide the switch....it should work....this is how I do that in the 2002 Max.....hope that helps. |
It's the economy, lots of things have stopped working!!! :D
thanks 2 go b4, that worked!! awesome. I thought something had gone bad. whew.
(Post 7777895)
Don't mention it! |
****ing theaves @ the dealership.. they told me it needed to reprommed again and it was not covered under the ext warranty. $45+tax out the door for this.
Originally Posted by file
(Post 8259332)
re: wow
Been awhile since I've been in here (Maxima is running well). Found this thread happily as I just changed out my battery, and the sunroof went dead. I was checking fuses, etc, but had that nagging feeling something went south with the battery swap.
You'd think with all of the electronics in cars today, there would be a special section in the owner's manual titled: "What needs to be reprogrammed when you swap the battery". As for that dealership - I mean wow, how to earn $45 and lose a lifetime of business. Keep it up boys, you'll work yourself right out of a job. |
© 2024 MH Sub I, LLC dba Internet Brands
