Rear Shocks replacement useful info
Someone posted on this forum about background noise from the rear after shocks replacement. Most likely, this noise is caused by improper assembly or using incorrect parts or both. You would think that rear shocks are piece of cake to replace, but it is not exactly true- keep reading if curious why.
1. Jack up one side of the car using hydraulic jack in the rear- work one side at a time. Careful with placement, do not force it on body parts, find piece of frame.
2. Place normal, classic jack in between notches and slowly lower the vehicle
3. remove wheel (yes, you got it right, pull parking brake and loosen wheel lugnuts first, which is step "zero".
4. Move hydraulic jack and place it under the spring.
5. DO NOT raise the spring, rather hold it in place
6. Loosen 17mm bolt hodling shock to steering knuckle, but do not remove yet.
7. Undo 2 12mm nuts on top. You do not have to mess with trunk lining, nuts are right there inside wheel well.
8. Compress the shock so lower part where big bolt is, is somewhat free, and let the bolt go. Wiggle shock outta there.
10. Use locking pliers to hold the rod on top and undo rod nut. Disassemble the shock. I recommend laying everything in order on the floor, do not screw up the order while assembling or you will end up having noise or other problems.
9. If you use KYB shocks, they will come with 2 bushings, metal sleeve, new nut, and a washer. Pay attention- smaller bushing that comes with new shock is shaped differently from OEM and most likely will not fit (no room for nut on top while putting everything back together). Hello, KYB, are you reading this? Solution: purchase shock mount kit beforehand, and use smaller bushing from that kit- it is shaped almost like OEM. Bottom line- you will need either purchase shock mount kit OR reuse OEM smaller bushing OR buy that bushing from nissan, if you want to do the job right.
Yes, do use big bushing that came with the shock (the one that sleeve goes into)
10. It is a good idea to replace shock boots. Pay attention for proper placement of bumper inside the boot, bumper comes with the boot and has to be twisted inside uintil it lands in the groove. Aftermarket boots and bumpers are entirely diferent from OEM, do not try to compare old shock with the new one during assembly.
11. When new shock is in place, slide boot down so it partially covers shock housing and push bumper all the way up unti it's flush with the bracket. If you do not perform this procedure, you are inviting water and dirt inside the shock.
Hope this helps and have a great afternoon.
Good write up. I actually just got my KYB GR-2's (front and rear assemblies) in with all the mounting hardware, boots, bushings, etc. I will be doing this farely soon, just waiting on some other parts.
You've got 2008? Car is probably too young for new struts or shocks unless you have an elephant or hippo or something. Do you do stop and go mostly or hwy commute?
HAHAHA. I am lowered on Eibach springs and I had read somewhere that it is recommended that you change your struts out every 40-50K. I do a little of both but I'd have to say mainly it's stop and go.
No, boots (we are talking about boot/bumper assy actually) are not included with your new shocks or struts. If you need boots for your monroe front struts, it is monroe part# 63619. As of rear shocks, it appears that monroe does not manufacture boots for them for this specific application, so try KYB boots in the rear instead, they may fit Monroe shocks.
oh ok , thanks. also a bit of infor for ppl who are planning to use monroe. they no longer make sensa trac. monroe now makes something called "monroe oespectrum" they replaced the sensa-trac. they brought this line in to aim more towards foreign cars as oespectrums was used over seas on forieng cars. i got oe spectrum shocks becuz they no longer made sensa trac, so i sent back my struts and got spectrums as well.
Regardless....nice write-up for someone who is doing this first time.
Go to Monroe Website
Actually they do still make Sensatrack. If you go on the Monroe website they show all of their products. You are correct that they do have OEspectrum for foreign cars.
ive been running eibach springs with kyb shocks for about 50k ish...3 years. i feel like the shocks are too soft and you feel mostly spring. anyone have a recommendation for a different brand strut to match the eibachs better?
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
