SRS (Supplemental Air bag System) light reset
Old Jul 30, 2011 | 07:51 PM
98maxi's Avatar
I found the process online and thought I would post it here since part of the process was missing. The following instructions ARE NOT MINE. I'm just posting them on the forum. It worked for me a on 6th generation Maxima. I edited the steps a little to make them easier to follow
Air Bag Light Reset
Originally Posted by bestatchess If you have the airbag light, it will show steady for a few seconds (the manual says 7 secs) after you turn the key from off to on (but not start) and then start to flash. Here is how to reset it:
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly and remove the key.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
Step 5 will require you to press the DDS (Driver's Door Switch, which is located on the driver's side pillar. The button is covered by a rubber cover)
5. Turn the ignition off, turn the ignition on (DO NOT START THE CAR) press the driver's door switch button 5 times within 7 seconds.
6. Turn the ignition off, remove the key, shut the driver's door, turn the ignition on and star the car. The blinking light should go way.
TAKE YOUR TIME TO DO THE STEPS. If you followed the steps correctly, it should work. Try the steps again if it did not work. Do the following steps if you have done everything correctly and if it still did not work, you may have a bigger problem
Here is the link to the original steps
http://wiki.answers.com/Q/How_do_you..._Nissan_maxima
Dennis Twohy
Oct 1, 2015 06:01 PM
95Maxi
Aug 29, 2015 09:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Samedi
Aug 13, 2015 04:05 PM
