help 07 idle problem
Old Oct 26, 2011 | 11:46 AM
fignewtin88's Avatar
07 maxima just did full 3.5 swap old motor had bad timing chain put the new motor in and it has high idle can figure out why already tried to reset the ecu cel keeps coming back any one have any ideas
Old Oct 28, 2011 | 10:17 AM
Lovemycar's Avatar
Why didn't they just replace the timing chain in the old motor?
Old Oct 31, 2011 | 09:08 PM
Really?'s Avatar
Timing Chain
Why did you replace the motor and not just the chain and related parts?
Old Nov 2, 2011 | 07:34 PM
shabnyc's Avatar
Most time the RPM needed to be reset by the dealer, via computer... If resetting is not working out for you ...Dealer is ur only option.
Old Nov 2, 2011 | 08:04 PM
CenTexSS's Avatar
I'd bet your throwing the P0507 ISC SYSTEM DTC.
Take her into your dealer and have an idle relearn performed. It doesn't take long, they shouldn't charge you more than an hour of labor. ~$100.
And why didn't you replace the chains/tensioners/and guides? You can do it with the motor in the car, takes a day or less if you know what you're doing.
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
