Questions on some required maintenance (door locks, window, trunk..)
Old May 29, 2012 | 09:39 PM
RnAoDm's Avatar
Hello everyone,
I recently became a proud '04 Maxima owner, however, I have some questions regarding fixing up some small issues of my car.
1. The front doors don't unlock with the remote or with the power function in the car. What is the problem here, I'm assuming the actuators need to be replaced? I can see the locks twitch slightly when trying to lock/unlock them with the power function.
2. The passenger side driver window rolls down slightly when rolling it up with the auto function. The only way to roll it up is if I roll it up manually (not using the auto feature). What is the issue here? Does it need to be adjusted somehow? To me it seems like the safety mechanism is kicking in for whatever reason.
I'm trying to do this maintenance myself where I can so just looking for some ideas of what parts are needed etc..
Thanks!
Old May 30, 2012 | 01:59 PM
06BlckMax's Avatar
The trunk doesn't pop open that's normal
Old May 30, 2012 | 02:54 PM
RnAoDm's Avatar
Thanks, removed it from original post.
Old May 30, 2012 | 08:53 PM
ATXnissans's Avatar
Well the locks is the actuators that are out and the window try the passenger switch to see if there is any play if it is then try replacing.g that if not then maybe ur regulator is out. But when the window falls u should try pulling the window up with your hand and see if there is any play if there is than that means the gears on either the window motor or the regulator
Old May 30, 2012 | 09:08 PM
CRiME's Avatar
oem ftw!
Since last week, my locks on the F & R passenger side also get stuck halfway when trying to lock. But, this only happens when the weather is hot. Do I need to replace the actuators as well, or does anyone have any ideas on how to fix it? anything on the inside that can be lubricated?
Old May 30, 2012 | 09:52 PM
RnAoDm's Avatar
Fixed the window tonight by following this guide:
http://nissanhelp.com/diy/maxima/pro..._procedure.php
Seems all it needed was a reset
I think I'll go ahead and get a couple actuators and fix this this weekend, shouldn't be too much more work considering I had the door panel off tonight already.
Old Jun 1, 2012 | 03:44 AM
Kryogen's Avatar
actuators are shot. buy new assembly from nissan, only thing to do.
Old Jun 2, 2012 | 08:19 AM
mrjasonlyrics's Avatar
My rear right passenger window does the exact same thing. If I use the auto it goes up and comes back down a few inches. Been to lazy to open a thread for it
Old Jun 3, 2012 | 01:58 PM
RnAoDm's Avatar
Ordered the parts from local Nissan. Was $220.44 CDN for both of the front ones. Will be here Wednesday
Honestly it's really easy to fix, shouldn't take more than an hour total.
Old Aug 15, 2012 | 06:56 PM
hpl912's Avatar
i have the same problem with the lock barely moving especially when the temperature is hot. I thought a lub will solve the problem but seems not...
so i would also need to replace the said actuators.
my question is are they easy to install?
are they these? :
King_Ten_Ahead
Sep 30, 2015 04:27 PM
rbaker100
Aug 31, 2015 11:09 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
shaunkey1
Aug 18, 2015 10:09 PM
kjm900r
Aug 5, 2015 07:14 AM
