Bank 1 catalytic converter removal?
Old May 31, 2012 | 08:58 AM
fernando6318's Avatar
hi everybody, so i just purchased a 06 maxima and have a p0420 code, also a loud whining noise after accelerating i'm convinced its the bank 1 cat converter, but am having trouble removing it.i dont know how to access the two top bolts that mount the converter to the manifold, two bolts have also snapped off during my attempt at removing them. can anybody offer a link or instructions on how to remove the bank 1 cat? your help would be appreciated.
Old Jun 4, 2012 | 08:53 PM
smokin5s's Avatar
http://www.justanswer.com/nissan/4kg...converter.html
what part number did you order? I have the same code...
is this the correct part? BOSAL Part # 0961454
Old Jun 10, 2012 | 02:23 PM
AscendantMax's Avatar
whining noise is most likely caused by worn out timing chain tensioners.
http://forums.maxima.org/6th-generat...l?ref=esp-link
Old Jun 17, 2012 | 10:42 PM
UchihaNismo's Avatar
You have to take off the 2 cowls to get to them. There's a plastic 1 and a metal 1 under that. Once you have both cowls and the wipers off then all your bank 1 stuff is easily accesable =) Then have to remove the heat shield on the exhaust manifold and either move it around until you can get a socket on 1 then the other, or remove the A/F sensor and take the heat shield out completly to get at those 2 upper bolts on the bank 1 cat. I just finished that job lol.
As for the whinning AscendentMax has it right, its the timing chain tensioner. Im in the middle of doing this right now. Drop your oil pan, I bet youll find the plastic piece and maybe some metal shavings. Dont wait too long to get that fixed. Itll only get worse and youll end up lossing the engine.
Hope this helps
Old Apr 2, 2013 | 02:53 PM
Scott260's Avatar
@unchiha
Did you have to remove the axle to get the cat out? I took mine to a shop today and they told me the axle would have to come out to make room to get the cat out. I did not think this was the case.
Thanks.
Scott
Old Apr 2, 2013 | 03:27 PM
06BlckMax's Avatar
you dont have to touch the axle they dont know what there doing
Old Oct 20, 2014 | 01:47 PM
johnlim123's Avatar
Catalytic converters
Early 2003 Nissan Maxima 200,000
I got a code of P0420 and P021?
can anyone tell me how much labor is involved in Bank 1 and 2? I think if they will give me a deal i will do both if not then one at a time.
I will consider upgrading to better Catalytic converters or(headers??) if the price is similar. please advise.. please tell me if the ebay ones are any good? or amazon ?
what is code P021?
this is brand new code i have never seen before..
Old Oct 22, 2014 | 05:44 PM
Les7311's Avatar
P021 is not a code
P0420 is a code.
Missing a number from the 1st Pcode
Old Oct 23, 2014 | 07:51 AM
ijustwnnahavfun's Avatar
p0420 is bank 1 front
while i think p0430 is bank 2 rear catlytic converter
the dealer will charge about $2000+ cdn
Old Mar 25, 2015 | 06:40 PM
gately66's Avatar
Bank 1 exhaust manifold heat shield removal?
Does anyone have an tricks or process on how to remove heat shield from manifold?
Bottom bolt is free, but the top two are not and bolts are rusted/rounded off so I can't remove. The heat shield is held well tho because of the top two bolts. Can i pry or cut off somehow? I've tried some things but not working.
Old Apr 7, 2015 | 10:21 PM
MiaRaider81's Avatar
my heat shield is loose
Did you end up removing heat shield yet? Mine is rattling almost every day
jmlee44
Oct 2, 2022 02:13 PM
hayne
Oct 5, 2015 11:53 AM
RealityCheck
Oct 2, 2015 06:34 PM
09maxshawn11
Sep 30, 2015 10:28 AM
jaydot901
Sep 29, 2015 01:18 PM
