Steering Rack
Old Dec 3, 2012 | 03:25 PM
goose44's Avatar
Steering Rack
I recently had my steering rack replaced and now I'm hearing a noise when steering on cold days, below 40 degrees. The noise will fade as I continue to drive. Any info would be great.
Old Dec 3, 2012 | 03:28 PM
nsnrider's Avatar
seven threads for the same problem? maybe use a search function?
welcome to the forums.
Old Dec 3, 2012 | 03:33 PM
Amerikaner83's Avatar
Check your PS fluid level...also check the pulleys and everything. Depending on how long it was, take it back to the mechanic who fixed it and have them deal with it
Old Dec 3, 2012 | 03:37 PM
tigersharkdude's Avatar
5 posts..and you've made 5 threads :SMH:
Old Dec 3, 2012 | 03:38 PM
T_Behr904's Avatar
Old Dec 3, 2012 | 03:50 PM
Greeny's Avatar
¯\(°_o)/¯
his phone was giving him a failure notice folks....he didn't know the duplicate threads were being created..
Old Dec 3, 2012 | 08:05 PM
CRiME's Avatar
oem ftw!
What does the noise sound like? If you could go into a little more detail, you'd be much more likely to get some helpful answers. If it's like a whining type of noise, check the power steering fluid as advised by amerikaner83. If it's low, add some ATF.
Old Dec 4, 2012 | 12:16 AM
goose44's Avatar
Fluid is fine. The noise is like a cracking popping sound. All steering functions appear to be fine, just the noise initially on cold days.
Old Dec 4, 2012 | 08:23 AM
L36's Avatar
L36
It might be the strut bearing or bad inner tie rod.
Old Dec 13, 2012 | 11:35 AM
goose44's Avatar
Strut bearing. Thanks
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
