Engine harness
Old Feb 22, 2013 | 12:42 AM
MajorReflexes's Avatar
Engine harness
hello guys. how hard is it to change an engine harness FOR AN 05 maxima
Old Feb 22, 2013 | 07:46 AM
NmexMAX's Avatar
dot dot dot ...
It be a major PITA do the entire thing. There are many sections, and many of those go into the cab, etc, what exactly is your problem?
Old Feb 22, 2013 | 09:17 AM
mrjasonlyrics's Avatar
I wouldn't suggest you do this if you don't know what you're doing. It's more critical connections than you might think and it could cost you a computer in the process. Let a professional mechanic do it. Oh did I mention it's one of the most costly parts on your car and you will only find it at the stealership?
Old Feb 22, 2013 | 05:24 PM
nsnrider's Avatar
if you're doing just an engine harness and not the whole under hood harness than its no hard at all. I do these often enough when I swap motors. Shouldn't take you more than 3 hours for the whole job. If you've never worked on your car, don't do it, let a professional do it since its too easy to forget a plug or a ground and chasing it after would be difficult.
I have 3.5 engine harnesses with auto tranny if you need a harness.
Old Feb 22, 2013 | 05:25 PM
i plugs that connect to the fuse box look chewed up
Old Feb 22, 2013 | 05:28 PM
im a diy guy i do almost everything, i had a lot of practice with my 4th gen. do i have to remove any parts for the harness Ex. manifold etc
Old Sep 1, 2023 | 01:01 PM
Allen hawk271's Avatar
Yes I it bad txt or call me at 8435365338ask for James
derekinthez
Nov 13, 2022 04:00 PM
knight_yyz
Oct 24, 2015 08:05 AM
