Rear Camber Bolt???
Old Feb 25, 2013 | 11:07 AM
Digital Alchemy's Avatar
Create From Nothing
Rear Camber Bolt???
I just came from getting a balancing and alignment. They were unable to adjust the rear camber. I'm running KYB/Tien S-Techs, and have read that I shouldn't need a camber kit.
I showed the guy the picture below, and he said all I need is the bottom bolt. It looks like it's the toe bolt. He said i need 4 of them. He would have to cut out the old bolt, and replace it/
Is there somewhere i can buy the camber bolt, and not the whole kit?
Any Info is appreciated.
Old Feb 25, 2013 | 11:49 AM
joecurr's Avatar
Unable to adjust it, or unable to get it in spec? With the toe bolts, it usually requires elongating the hole, not sure if you'd rather do that than just using camber arms. Anyways, the SPC toe bolts are available separately.
http://www.amazon.com/Specialty-Products-Company-72055-Camber/dp/B000IYFZ5S/ref=sr_1_3?ie=UTF8&qid=1361821585&sr=8-3&keywords=spc+toe+bolts http://www.amazon.com/Specialty-Products-Company-72055-Camber/dp/B000IYFZ5S/ref=sr_1_3?ie=UTF8&qid=1361821585&sr=8-3&keywords=spc+toe+bolts
Old Feb 25, 2013 | 01:21 PM
Create From Nothing
1st...beautiful max, and thanks for the link
2nd...
the paper work the guy gave me says. "UNABLE TO ADJUST REAR CAMBER. NEEDS FOR NEW REAR CAMBER BOLTS". I'm not 100% that he means toe and not camber. i thought there were only 2 camber arms, and 4 toe bolts. Also I found some parts on rock auto, But it looks like they are all for the front, are the bolts the same for the front and the back?
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
ef9
Sep 5, 2015 11:18 PM
Maxboy23
Sep 4, 2015 06:04 PM
