Rear rotor is very loose and tire sits at slight angle
Old Mar 11, 2013 | 07:37 PM
dhornb1's Avatar
hey gang, I need some serious help!
Was changing rear passenger brake pads and when i went to put the tire back on i noticed that the rotor was very loose. I know the rotor needs to be replaced since its worn down beyond the point of having it turned. I figured it would be OK for at least another day or 2 but after i firmly tightened the lugnuts i can grab a hold of the tire and shake it and when there's weight on the tire it sits at a slight angle..I hope this is just because of the bad rotor or could it be something more?
Old Mar 11, 2013 | 09:25 PM
gatsugansu's Avatar
your hub bearings are shot.
Old Mar 11, 2013 | 09:34 PM
CRiME's Avatar
oem ftw!
Yep, I replaced mine with a timken set, got the set for about $150. Install was pretty easy, the rear wheel hubs are held on by just 4 bolts that are accessed from behind. Added benefit, if you change the hubs you can keep the ABS problem at bay. That's actually why I changed my rear hubs in the first place
Old Mar 13, 2013 | 05:08 PM
Kryogen's Avatar
ya it's probably your worn rear rotor causing ****ed up tire issues, change the rotors. change your pads too.
Old Mar 14, 2013 | 08:55 AM
dhornb1's Avatar
Yeah I started to suspect the bearings after I posted. Sure enough it was shot to hell. Went ahead and replaced both rotors too while I was at it..Whole job cost me about $215..Good as new now.
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
