20 inch rims
Old Mar 31, 2013 | 06:49 PM
757golfnut's Avatar
20 inch rims
Need help!! with installing 20 inch rims on 06 maxima,not sure
what issues i will incounter??
Old Mar 31, 2013 | 08:22 PM
06BlckMax's Avatar
none with the right specs
Old Apr 1, 2013 | 08:48 AM
757golfnut's Avatar
what are they talking about when they reference gaps and spacers
Old Apr 1, 2013 | 08:55 AM
06BlckMax's Avatar
Old Apr 1, 2013 | 03:12 PM
NmexMAX's Avatar
dot dot dot ...
Who are "they"? They talk a lot don't they?
Old Apr 2, 2013 | 08:47 AM
Thasa's Avatar
I have 20" rims on my '04 but had to make sure I had the right size tires and offset for the rims to make sure there was no rubbing. I have 20x9 in the rear with a +35 mm offset running 255/35/20 tires and I had to slightly trim the inner plastic edge where the bumper meets the fender. I don't recommend rolling the fenders unless your getting it done properly because they will eventually start rusting if you don't.
You can save yourself the headache and get rims with an offset around +45mm and you should have no problems even if you decide to go 275/30/20.
Just pay attention to the offsets, do a little research online and you will see the higher the offset the closer the wheel is to the hub.
Goodluck
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Garrettz459
Sep 28, 2015 02:50 PM
Luigi623
Sep 21, 2015 01:42 PM
Serotta33
Sep 17, 2015 12:14 PM
