Disconnected battery leadsto check engine light ?
Old May 26, 2013 | 12:56 PM
Allisinthepass's Avatar
Title pretty much sums it up, i had to work with the doors open and electric bits so I disconnected the battery (twice, connected it up to check and took it back off again) and after I put everything back and went for a ride the CEL came on. The car was running find, great idle and everything was normal. I have had the car for almost a year, i do regular maintenance, I just had the oil changed 2 weeks ago. I cant think of anything else that I did that would suddenly cause a CEL...
Old May 26, 2013 | 02:36 PM
6thgen's Avatar
What part were you working on?
Swing by an autozone and see what code is pulling up.
Also, how long have you had the maxima for?
Old May 26, 2013 | 02:48 PM
smittybizzle's Avatar
Please just check the code first.
I have had this happen and it goes away after a day or two.
Old May 27, 2013 | 04:33 PM
i just did the ecu fault code test and it only came up with P0651 and the only thing that i could find on google was: P0651 Sensor Reference Voltage B Circuit/Open...
Old May 27, 2013 | 08:17 PM
Clear the code and see if it comes back.
Old May 29, 2013 | 10:11 AM
Costee's Avatar
Yes you can do that. The code does not seem to be available (applicable?) for Nissan. It's not in the 2006 ESM for instance.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Superbform
Aug 11, 2015 08:10 PM
