lowered help
2 Attachment(s)
Hello everyone just needed some advice from everyone that's lowered. Currently I'm on Teins and want to go with some coilovers very soon. My question is what are you guys doing about the rubbing on the rear for the bumper support? Right now with my setup I get a slight rub on the tire with no damage to tires or wheels. I have rolled the fenders somewhat and don't see any interference there just on the bolt that sticks out towards the rear of the fender well that most of you have run into I'm sure. The pics show how low I am, I know it sags a small amount in the rear with a full tank of gas and the 12's in the trunk but I don't want to go lower till I know what I need to do with this bolt.
Welcome to the rub on the fender club. You will have to try many things before you get it right because the lowering with stiffness, size rims, tires profile, rims offset, and weight you're carrying around i.e passengers, subs and box needs to be put into consideration. That part that sticks out from the bumper and fender will have to shave it a little and it should clear a little more room for when the car sags from passengers.
I don't think you should get coilovers for the 6thgen Maxima's because it's going to be a very uncomfortable ride seeing that you have low profile tires and speaker box with amps. These set ups are usually for sport/racing but that's just my stupid advice. Good luck on the whip |
You are not rubbing on that little tab, you can break that off with some pliers thou. You are rubbing at the bracket that holds the rear bumper to the quarter panel. You can shave it off and screw it on at a different location. Also running a less wider tire can help also.
Originally Posted by hero782
(Post 8808845)
MrJason I have to go coilovers because I cant afford bags like I want, so for now the coilovers will do the trick. The Tein's and 20's already took all the "comfort" out of the ride as it is. Sorry for the late response back to my own thread as well. It was a busy fathers day weekend, and I replaced 3 motor mounts on the MAX. |
Please don't take any offense when I say this but why would you want to lower your car if its just going to give you problems? I know it does look good but is it worth it?
Originally Posted by Borker
(Post 8811255)
1 Attachment(s)
Originally Posted by jperez77
(Post 8811220)
So this little tab has got to go. Did you also relocate this screw that you're speaking of?
Attachment 31001 |
(Post 8811220)
Thanks Hero I plan to go to a smaller tire like you suggested to me before in another thread. I just bought these 275's without really planning out the direction I needed to go to get this "flush" look. I'm already looking into some spacer to bring these high *** offset wheels down. So this little tab has got to go. Did you also relocate this screw that you're speaking of?
Thanks joecurr for the pic!
hero and joecurr are right. i did the same thing when i went with wider wheels.
© 2024 MH Sub I, LLC dba Internet Brands
