Battery Change, and Car Settings
Old Aug 8, 2014 | 05:06 PM
LandsEnd's Avatar
When you change out the car battery do you lose all radio, and dashboard settings? If, so how can I save them? I don't wan't to deal with resetting a moon roof, and a radio code to work the radio.
Old Aug 9, 2014 | 02:32 PM
Kryogen's Avatar
I usually loose those, but they sell some "things" on amazon to keep radio settings. search amazon.
Old Aug 11, 2014 | 11:33 AM
nupe84's Avatar
Really!??
Old Aug 11, 2014 | 02:37 PM
LandsEnd's Avatar
I got battery changed today with no memory saver because I called the Nissan dealer first. The radio does NOT lock up he told me, and he was CORRECT. The only thing I had to do was reset sun roof, and saved radio stations needed to be reprogrammed in. All other settings stayed same including stuff under the maintenance, & settings buttons.
Old Aug 11, 2014 | 02:52 PM
tosheto's Avatar
I took the battery out of my Maxima for 1 year and never had to do anything with the sunroof.
Old Aug 13, 2014 | 02:38 AM
Scramblinman's Avatar
I have replaced the battery in our Maxima twice now and the only things I remember needing to reset were the radio station presets and the memory seat settings.
Old Aug 13, 2014 | 05:55 AM
ateick's Avatar
Autel sells a Memory Saver device. Basically you plug it into the OBD port, connect the other end to a battery, remove and replace the battery under your hood, unplug the Autel unit from the OBD port and you are good to go. None of your presets or settings have lost power so they remain the same.
Old Aug 13, 2014 | 07:11 PM
chrome91's Avatar
hook up a booster pack to your battery terminals. loosen the terminal bolts, have someone hold the booster pack clamps with the terminals still clamped up, replace the battery, hook up the clamps again, tighten clamps, remove booster pack. boom, no lost memory. ive used that method hundreds of times
theres also booster packs that have a cigar lighter attachment for this purpose, easier method
Old Aug 15, 2014 | 09:14 AM
Jhaysmooth's Avatar
Hi,
When I turn my car on and it dies 2 seconds after what does that mean?
Old Aug 15, 2014 | 05:12 PM
chrome91's Avatar
Originally Posted by Jhaysmooth
Hi,
could be 5 billion things. does it run if you keep giving it throttle?
could be the security system, could be the fuel pump, could the the ECU, could be a massive vacuum leak, ..............
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
RealityCheck
Aug 5, 2015 06:18 AM
