Audio Fuse Problems
Old Sep 15, 2014 | 05:39 AM
mechasaultfreak2's Avatar
Audio Fuse Problems
Now I don't have any type of modded audio system for my maxima, it is all stock. But ever since August my audio fuse started to mess around with me. The car sits outside also and never had this problem when it sat in the garage till now which it sits outside. But anyway... The fuse problem only happens in the morning and continues to have it till I move the fuse around. Once I move it up right or left the audio starts to work again. So I guess that means the fuse is good. But then again it stops working this morning. Now I spent 10 minutes trying to get it to work but was running out of time so I just went to school. This is bothering me since I am never in my car without my music unless I want to relax. So could I need a new fuse, fuse box, circuit? Please help. Thanks
Old Sep 16, 2014 | 07:38 PM
DennisMik's Avatar
Try unplugging and replugging the fuse half a dozen/10 times and see if that helps.
If not, the fingers that hold on to the fuse could be coming loose. Remove the fuse and bend the legs just a tiny little bit and the halfway point. This has the effect of making he leg thicker.
Old Sep 17, 2014 | 05:15 AM
MadMax07SL's Avatar
so you guess the fuse is good? did you replace it anyway to eliminate it as the variable?
conansriver
Sep 11, 2015 10:26 AM
jwright36
Sep 8, 2015 11:45 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
