Still stuck in failsafe mode 04 max
Old Oct 10, 2017 | 02:41 PM
TriggaB21's Avatar
After changing all the sensors that I have changed which includes the cam position sensor bank one because it gave me a code P0340 I changed it twice none of the sensors seem to be working.. I've purchased the sensors from Arch Auto Parts and AutoZone and they have done me zero Justice period. Now the codes that are on my car are p0011 and P0340. How can I get my car up and running again what am I going to do about the p0011 and could the cam position sensor be causing that code.. because I was told they both work in unison.
Old Nov 1, 2017 | 07:39 AM
smittybizzle's Avatar
For the cam sensors I would definitely check the harness that sounds like your issue for bank 1. Does the car stall and die sometimes? I put a description for P011 on the bottom, could be the timing solenoid, but again I would check the harness first. Have you been keeping up on the oil changes? Worst case the P0011 is due to faulty oil gallery gaskets, at that point if the timing job hasn't been done now is a great time to do it.
https://www.autocodes.com/p0011_nissan.html
