07 Maxima Crank/No start
Old Mar 14, 2022 | 07:16 PM
Kyle11's Avatar
Good evening,
I have an 07 Maxima that cranks/no start. I plugged in a generic code scanner and received no communication. The radiator fans would run on high with the ignition on the run position. Purchased a programmed ECM online that is programmed to the VIN. I am still having the same issue. Any ideas of what to check.
Kyle
Old Mar 15, 2022 | 06:50 AM
RA030726's Avatar
I'm nutty for Nissans
Did you pair the key to the new ECU?
Old Mar 15, 2022 | 07:03 AM
Kyle11's Avatar
have not done anything besides install the ECM. Is there a process for programming the key? I just assumed it was already completed when it was sent to us as functions on the remote work with the exception of the unlock.
Old Mar 15, 2022 | 01:46 PM
RA030726's Avatar
What is the security light doing?
Search for NATS (nissan anti theft system) or immobilizer programming. The new ECU has to be paired with your specific key(s). You can do it with the correct software, OBD (or Consult?) cable, and a computer. Or get a locksmith or dealer to do it.
Old Mar 19, 2022 | 03:49 AM
TDGrant's Avatar
Old Mar 19, 2022 | 05:10 AM
Kyle11's Avatar
Update. Had vehicle towed to dealership. They found that the place that done the kids oil change installed the air filter box improperly and it rubbed the wiring of the Mass Air Glow sensor. Causing the no start issue.
Old Mar 19, 2022 | 05:11 AM
TDGrant's Avatar
Ah, crappy waste of money. Glad you sorted it out, Kyle.
rellsmaxi
Jun 5, 2018 07:31 PM
BareFooTxx
Nov 12, 2016 05:15 PM
Richkid739
Nov 16, 2013 01:20 PM
MaxBlu5
Jul 22, 2006 05:11 PM
