6th Gen Radiator WITHOUT Trans lines
Old Mar 18, 2024 | 06:29 PM
MEM2005's Avatar
Hi All, hoping for some clarity on my radiator. Sprung a leak so I whipped it out and bought a new one, The problem is mine doesn't have the transmission lines (it has a separate cooler), and I can only find versions WITH the transmission lines.
The model is 2005 SL Automatic
When I search for the radiator using the part number on the radiator I removed, it brings up the version with the transmission lines and Nissan have told me they only make the radiator WITH the transmission lines. Pictures attached.
Any advice on where I might find one the same? Thank y'all !!!
Old Mar 18, 2024 | 07:32 PM
RA030726's Avatar
I'm nutty for Nissans
Autos get a cooler in the radiator. Manuals do not. Nissan may not offer a rad without the internal cooler anymore. I would guess someone swapped radiators and added an aftermarket external cooler. The good thing is you wouldn't have to worry about the radiator failure where the 2 fluids mix and kill the trans.
Can you post a picture of the other trans cooler on the car?
Old Mar 18, 2024 | 08:49 PM
MEM2005's Avatar
Ok that’s what I’ve been seeing elsewhere, I think these pics are the cooler?
I wonder if it’s possible to replace with blanks where the connectors are?
Old Mar 19, 2024 | 05:22 PM
RA030726's Avatar
That looks factory. You know, the more I think about it, maybe the 5AT does not have a cooler in the radiator. I've never actually seen a 5AT in person. The part number is
21410-8J100
https://www.nissanpartsdeal.com/part...OTH;5=SE;6=5AT)
I wouldn't worry about the replacement rad having the cooler fittings. Just cap them off.
Old Mar 26, 2024 | 07:34 PM
t_buzz's Avatar
Ended up with the same issue, just ran a piece of hose between the two fittings that was tight enough to not hang down but had enough slack to move a little with pressure, hose clamped in place and have had exactly zero issues in the 4 months since installing it.
Old Mar 27, 2024 | 01:01 PM
MEM2005's Avatar
I found a company that manufactures them, Throtl
jchronis2552
Sep 23, 2015 04:57 PM
toodark
Oct 23, 2014 03:21 PM
ffcbairn
Feb 11, 2013 04:01 AM
laflyer23
Dec 17, 2007 09:09 AM
