question about potential CEL after changing all 4 tires
Old Apr 9, 2026 | 12:40 PM
s12_200zx's Avatar
I noticed that after replacing 1 of the tires from standard 245/45/r18 to a 225/50/r18 (all I could get at the time), I noticed multiple CEL lights of ABS, TCS off and SLIP as I started driving. If I were to replace all 4 tires from 245/45/r18 to either a set of 4x 225/50/r18 or 4x 255/60/r18, will I still run into that CEL light situation ?
Thanks.
Rudy
Old Apr 9, 2026 | 01:31 PM
slvr2KSE5's Avatar
that SHOULD be close enough to not cause a problem but if the tires are at the opposite extremes of size limits it might. tires do vary in actual measurement. the same 245/45/18 from different brands could be very different in actual size.
Old Apr 9, 2026 | 02:14 PM
s12_200zx's Avatar
Trying to figure out if any of the following are within the 3% deviation limit (if it even matters considering all 4 tires will be replaced with identical dimensions)....
225/50/r18
255/60/r18
245/40/18
You would think 245/40/18 would be within that 3% limit but does it really matter in the overall scheme? I understand why it went to cell when there was a mismatch of 3 x 245/45/r18 w/ 1 x 225/50/r18. Appreciate any input before I fork out 5 to 6 bills for new Michelins or Toyo sets and to be stuck w/ the same CEL errors.
Old Apr 9, 2026 | 03:09 PM
slvr2KSE5's Avatar
if all 4 are the same size/brand it doesnt matter.
Old Apr 10, 2026 | 08:35 AM
Craig Riker's Avatar
Tire size difference
Thanks.
Rudy
The difference in tire size 50 verses 45 may be enough to throw off the output of the wheel speed sensor. The sensor sends pulses to the cars ECM, if the pulses doesn't match the other wheels it's going to send a code.
Steve68
Wheels/Tires
Aug 20, 2008 11:48 AM
maximus24
Tires and Wheels
Jan 20, 2005 08:13 AM
madmax2k
19
Aug 21, 2001 07:51 AM
