Regular Vs. Premium: Who's using what?
)The fact that I live next to a BJ Wholesaler Gas station - the 93 octane tends to be much much cheaper than Exxon's midgrade.
I live near Costco, gas is cheap but contains 10% ethanol, which I'm not happy about.
I only check something like that when I first get the car, and since I got the first '09 back in July '08, I never opened the book again until this past August when I got the '11. Either way, I only do and will only ever put 91 at a minimum in this car. Like others have said, it is only a $3-$5 difference at the pump.
I have had my max for 1.5 yrs now. I find if I use less than 91 for more than a fill up, the engine does not sound as smooth. Could be in my head?? Find I cheat a lot less these days. Never use below 89 now.
FYI - never noticed an improvement in gas mpg's using premium . . .
I use 91/93 octane the first 18 months of each new Maxima, then switch to 89. I have never noticed any change in the way the car ran, and I am rather **** about the sound of my engine.
on the topic of octane levels, i just moved to dubai and am on the verge of buying my 1st Max (dont wanna jinx it). At the pump,the minimum octane here is 95 & you get 98 too. how insane is that. oh and also somebody fills gas for you while you sit inside ur car. all this for less than $2/gallon.
87 AKI = 91 RON
91 AKI = 96 RON
Having been in several parts of the globe (USA-Italy-Saudi Arabia-Philippines) - there are variations on what the number actually is. In the USA - AKI is the common number used (at least it NJ-NY) while RON is used in the Philippines.
If I'm not mistaken, RON is used pretty much elsewhere outside of North America (go figure!)
Is this RON or AKI?
87 AKI = 91 RON
91 AKI = 96 RON
87 AKI = 91 RON
91 AKI = 96 RON
Excellent read, Monte.
A key part for me:
'A common misconception is that power output or fuel efficiency can be improved by burning fuel of higher octane than that specified by the engine manufacturer. The power output of an engine depends in part on the energy density of the fuel being burnt. Fuels of different octane ratings may have similar densities, but because switching to a higher octane fuel does not add more hydrocarbon content or oxygen, the engine cannot develop more power.'
That tells me that, even if we could find 100 octane gasoline for this Maxima, it would not get any better fuel eficiency (MPG) than we are getting running fuels with octanes within one or two of 91 (the recommended octane).
But then automotive engineers have been telling us this since the 1960s. The problem is that urban legends and our emotional desires always trump scientific research.
Thanks for the reference, Monte. Great read.
A key part for me:
For the record, I use Premium.
But, I thought I read on this thread where someone stated that the mid-grade and premium gas was stored in the same underground tank? If that's true, why pay more for premium if you can by an "upgraded" midgrade? The octane levels should even out with the mixture and essentially, the 89 mid-grade is actually a 91?
I'm just thinking out loud. I gassed up yesterday and had this thought while I was standing there..
When I accelerate, it gets a lil groggy at low RPMs, like 1200-1400, then when I give it a little more, totally fine....I just got the car and believe the dealer used unleaded. Could that be because of not using premium?
Actually, there are two tanks, one for regular and one for premium. Mid-grade is the combination of both, i.e. when you select midgrade fuel, it pumps from both regular and premium tanks at the same time.
RayFan is absolutely correct.
As information, the 7th gen Maxima runs beautifully on midgrade, and octane is not directly connected to fuel efficiency, so the octane drop does not affect MPG.
We would expect similar performance with midgrade and premium, since the fuel system of the 7th gen Maxima is set up for 91 octane, and so the 89 octane of midgrade is very close to that specified 91.
But regular (87 octane) is another matter. A few here have been able to run with 87 octane, although Nissan specifically tells us in the Owner's Manual to not do any aggressive driving if we find ourselves in a situation where we have to use 87 octane, and to switch to a higher octane at the first opportunity. Several here who tried regular (some by accident) found their car missed and stuttered on regular.
I have always switched from premium to midgrade after 18 months in every Maxima I have ever owned (at least one in every generation except the first), and never had any change in performance or MPG. I don't do this to save money, although the difference between midgrade and premium is usually around 20 cents per gallon where I live. I switch because my car does not need 93 octane to perform perfectly.
Yeah Lexus's are real sensitive to that matter, I once put 89 in my fathers GS450 by accident and it knocked a bit and did not perform the same. He drove it later and asked what kinda gas did i put in it I said ooopps...lol.
Wow! I am surprised Toyota can't do better than that. Especially in what is supposedly their upscale brand. All seven generations of the Maxima run perfectly well on premium or midgrade. We have had examples here on the ORG of a few 7th gen Maximas that ran decently on regular. I hate to think how bad a Lexus would run on regular.
NEVER THOUGHT ABOUT IT B 4 BUT SINCE IM READING THAT U CAN FEEL THE DIFFERENCE IM GONNA WAIT TILL NEXT FILL UP AND USE PREMIUM ANYONE KNOW HOW TO CHEAT THE CHIP WITHOUT VOIDING THE WARRANTY SINCE MY MAX TOPS OUT AT 134 MPH
Midgrade works perfectly. I can easily afford premium, but careful comparison showed me that, for my driving, the car performs the same on midgrade or premium, and gets the same MPG on either. So, for me, premium is a waste of money, especially since I live in an area where premium is 20 cents a gallon more than midgrade.
If I were racing the car, or making elapsed time runs, then I would automatically use premium.
I use 93 from BJs and it seems to work fine. I assume it's probably not the highest quality fuel since it's significantly cheaper than surrounding stations, but there aren't a lot of local options with 91.
Most 7th gens run poorly (or very poorly) on regular.
I have an '02 i35 and I use premium. I've read various articles that quote execs at GM, Toyota, and other companies saying it usually doesn't matter for the driving that we do day to day but I tend to get myself in turning situations that I really should have waited for
So those milliseconds count at times like that. Damage wise, I don't see it doing much damage since it's designed to adapt to regular. On my '02 I don't care if regular damages it. If I bought a '12 I'd put premium in it. Preferences vs Priorities i guess
