Black steel wheel winter tire package question
Old Dec 16, 2008 | 04:59 PM
joeyg's Avatar
Hi, is anyone running the standard black steel wheels and winter tires on their 2009 Maxima?
I didn't see Tire Rack offering a steel wheel option, so my question is will in a 17" steel wheel fit?
Joe
Old Dec 16, 2008 | 05:15 PM
michaelle8885's Avatar
what is a steel wheel?
Old Dec 16, 2008 | 05:27 PM
BobXX's Avatar
Not an alloy wheel...
Old Dec 17, 2008 | 01:27 AM
choice89's Avatar
You pose an interesting question and I am wondering what you are trying to achieve.
Old Dec 18, 2008 | 04:24 AM
lightonthehill's Avatar
Not meaning to put words in Joey's mouth, but I would guess he faces the situation that winter tires are taller and narrower than OEM tires, and to fit them inside the fenders, he has to step down to a 17" tire. It is VERY important that there be GOOD clearance between winter tires and fenders, ESPECIALLY if there is even a slight chance chains might be used. He may be going with steel because it is always stronger and cheaper than alloy. And he may be going with black because it looks good on his car.
Oh, well; looks like I stuffed Joey's mouth full of words anyway . . .
Old Dec 18, 2008 | 01:05 PM
joeyg's Avatar
Kinda like that. The steel wheels and winter tires are the most economical option, but the steel wheel manufacturers only make them up to 17" in size. My wife's 2003 Maxima had the steel wheels and winter tires on 16" steel rims and had no problems whatsoever. I just want to make sure that 17" rims with clear the brake calipers etc. I don't plan on using chains so there is no issue there.
Joe
Old Dec 18, 2008 | 01:18 PM
joeyg's Avatar
Old Dec 18, 2008 | 01:44 PM
Torgus's Avatar
seriously like how can you not just search for such a simple question?
i mean we love to spoon feed on here but...
Old Dec 19, 2008 | 06:37 PM
fdcarguy's Avatar
I went with an alloy wheel from tire rack and hankook iPike snows. I was a bit hesitant to try this tire on account of its T speed rating but I have been quite pleased I carved my way home in 6 + inches of the white stuff. In dry condtions it is very stable, not loud or wobbly and good in standing water. It looks very aggressive and has the same tread pattern as Hakkapellitta RSI and costs considerably less. Anybody looking for a good snow should give it a rip.
Good luck trying to find a 17 inch steel wheel I checked several tire shops both brick and mortar and online and could not find a 17 inch steelie.
Old Dec 19, 2008 | 08:01 PM
04BlackMaxx's Avatar
I couldnt find a steel wheel package in 17 or 18" for my 04 so I ended up just using the stock rims with all seasons for winter.
Old Dec 20, 2008 | 03:34 AM
Have not the slightest hesitation. 'T' rated tires are designed for prolonged driving at 118 MPH, and I would not expect them to fail in shorter runs around 125 MPH. Few folks will be going much faster than that with their winter tire setup.
Old Dec 21, 2008 | 07:45 AM
fdcarguy's Avatar
That's what the tire guy said...
It started snowing in Friday here in Central MA and has not stopped, and we have been "wrecking the malls" taking the Max and leaving the MDX in the garage.
Very happy with how the Max does in the snow.
Old Sep 26, 2009 | 08:31 AM
nissan_wannabe's Avatar
fdcarguy,
Hate to revive an old thread, but I am looking to purchase a set of winter wheels and tires for my 2009. I too would go with 17 inch steelies if they were available. Which alloys did you end up getting? Do the centering rings work properly? Did you get the 18 or 17 inch wheels?. I am looking at the 17 inch wheel options at Tire Rack. Thanks for any advice.
MplsMadMan
Sep 4, 2015 02:23 PM
homeyclaus
Sep 3, 2015 06:15 PM
cheftoo
Aug 24, 2015 09:20 AM
Ispeedbyu
Wheels/Tires
Aug 21, 2015 02:40 PM
